Design Templates User Guide
Modify : Modify Angle
The Element Angle window allows the user to define the Angle attribute for any primitive which has, for example, the angle subtended by the end faces of a torus or the swept angle of a solid of revolution.
On the Design Templates tab, in the Modify group, click Angle to display the Element Angle window.
The user is prompted to Pick Item to be modified :
The user is prompted to Point Start is to pass through (Distance[0] Snap :
The Positioning Control window displays by default, refer to Common Functionality User Guide for further information.
The selection becomes inactive if the Start radio button is selected.
The user is prompted to Point End is to pass through (Distance[0] Snap :
The selection becomes inactive if the End radio button is selected.
Select the Start radio button to lock the start point of the primitive.
Input an explicit value in the Angle field to define the angle.
The field becomes inactive if the Angle radio button is selected.
Click Apply to modify the angle of the primitive or Dismiss to discard any inputs and close the Element Angle window.
