Click to display the Local Name window, refer to Assign Local Name to Template Element for further information.
The user is prompted to Pick item to copy rules :
Click to refresh the Template Member Parameters window to include all updates.
Click to remove data from the Expression field.
Click to test the data in the Expression field. If an invalid command is input into the Expression field, the user receives an error message summarising the problem.
