Input a property description into the Description field.
Input a property value into the Key field.
Input a property number into the No. field.
Allows the user to define an evaluating expression, Expression Builder is activated by default in the Data part of the Define Template Properties window, refer to Expression Builder for further information.
Select a data type from the Type drop-down list.
Input a default value in the Default field.
Input an expression value in the expr field. For example, HEIG of PLOO 1 of PANEL indicates the Height attribute of the Panel Loop element owned by the Panel.
Allows the user to input acceptable minimum (From) and maximum (To) values for the property. When the Design Template is used in a design instance, only values in the specified range are accepted.
Allows the user to select an item for a Specification Reference using a cursor pick in the 3D view. The user must select Specification Ref from the Definition drop-down list of the Define Template Properties window.
The user is prompted: Pick Item that SPREF is to be selected from :
Click to replace the selected property with the display values in the Define Template Properties window.
Select from the list of properties, the property displays in the Expression field.
Select Current, Local or Template from the Properties drop-down list to define the list of properties.
Select from the list of local names, the local name displays in the Expression field.
Select from the list of functions, the function displays in the Expression field.
Select from the list of operators, the operator displays in the Expression field.
The List of Valid Values should include the default value entered into the Data part of the Define Template Properties window to make sure that a designer can easily reset the value if a change is required.
Select Plotfile from the drop-down list to create a plotfile property.
Select PPLT from the drop-down list to insert a portrait plotfile property or select LPLT to insert a landscape plotfile property.
Input a filename in the field directly below the Type field with a .plt suffix.
Select Sub Element Ref from the drop-down list to insert a reference to sub-equipment property.
Select Sub Ref from the drop-down list to insert a reference to a sub-equipment property.
Allows the user to define specific sub-equipment values for the property. Refer to Define Valid Values for further information.
Click Add CE to include Current Element in the List of Valid values.
The user is prompted to Identify Element to use :
Allows the user to define sub-equipment rules for the property. Refer to Define Sub-equipment Rules for further information.
Input a rule description into the Description field.
Leave the selection as Sub-Equipment Reference from the drop-down list.
Input a rule into the Key field. Alternatively select Attribute Rule Expression Builder to create an associated rule, refer to Attribute Rule Expression Builder for further information.
Click to replace the selected rule with the display values in the Associated rule definition window.
Select from the list of properties. The property displays in the Expression field.
Select from the list of local names. The local name displays in the Expression field.
Select from the list of functions. The function displays in the Expression field.
Select from the list of operators. The operator displays in the Expression field.
