Design Templates
Create Design Template
The Design Templates application makes the assumption that a new Template is based on an existing set of design elements (or on a predefined Design Template). The user must create design elements and copy them into the Design Template.
A Design Template is a set of design primitives, panels and nozzles that may be grouped together and then referenced from within another part of the design database as though it were a single item. In many ways, a Design Template behaves in a similar manner to a catalogue component, except that the template items are stored in a special area of the DESIGN DB, rather than in a separate Catalogue DB. Design Templates can use the more powerful sets of primitives and parameterisation facilities available from within MODEL. Unlike a catalogue component, a Design Template can be split down into its constituent parts for selective manipulation and reporting.
A Design Template is used in a design by creating an instance of the template in the DESIGN DB. When a Design Template is instanced, the contents are copied into the design hierarchy; they may then be modified locally as required.
A Design Template may be referenced from Equipment or Sub-equipment, a Panel Fitting, a Section Fitting or a Primary Joint.
