DRAW Reference Manual
Plot and Drawing Output
: Plot Command
Plot Command
Supports printing, PDF, AVEVA PLOT and basic DXF export.
Basic DXF export is a monochrome export with either white or black graphics.
Plot command format:
PLOT AREA <FORMAT> <FILE> <FileName> <OPTIONS> <PAPERSIZE> <CUT OFF> <BORDER N> <FRAME> <SCALEUP N> <OVER>
Example:
PLOT SHEE PDF /S3.PDF 'PLOTSTYLE "GREYSCALE", REDUCETOFIT' A1 CUT OFF BORD 25 OVER
AREA
Area to be exported or printed. DRAW supports only whole picture or single view. The argument can be SHEE or explicit picture or view name proceeded by "/" character. If the area is the text "SHEE" the sheet currently selected in Draw Explorer is exported.
FORMAT
Plotting format. Can be one of:
PRINT - prints the drawing on current printer.
DXF - export the drawing to DXF format (NOTE: this produces a basic monochrome export using the specified options. Additional configurations are available. Refer to
LIEXEC Command
for further information).
PDF - exports the drawing to PDF format.
IMAGE – exports the drawing to an image format as determined by the filename extension. For example, .PNG, .BMP.
The parameter is optional. Where not given AVEVA plot file is generated.
FILE
Keyword used for backwards compatibility, instead of FORMAT, for exporting the AVEVA Plot file.
FILENAME
File name for file base formats (PDF, DXF, PLOT). File name must be preceded by "/" character.
OPTIONS
Additional export options given as string. Refer to
Additional Options
for further information.
PAPERSIZE
Paper size: A0, A1, A2, A3, A4
CUT OFF
By default the rectangular limit of the plotfile displays; this can be suppressed by CUT OFF.
BORDER
The BORDER value option causes a border to be left within the specified paper size.
The image size of the item being plotted is reduced accordingly.
FRAME
The FRAME option causes a frame to be drawn around the image; FRAME can only be used in concert with the BORDER option and marks the inside edge of the border. It does not control the frame around the edge of the plotfile.
SCALEUP N
Additional scaling factor. Used only by DXF export.
OVER
Overwrite the output file if exists.
Additional Options
Additional options given as string to PLOT command and separated by commas:
REDUCETOFIT
EXPANDTOFIT
Fit to paper
VIEW
NOVIEW
Plotting a PDF file has the option to automatically launch the reader by selecting the VIEW option. The option NOVIEW is also available and is the default.
PLOTSTYLE "Name"
DRAW introduces plot styles. The plot style can be selected in batch printing with the PLOTSTYLE option. The name should be given in double quotes if it contains spaces.
OWNERFRAME
Use this option to allow plotting owner frames. If not given, frames are not exported.
BLACKBG
Export to DXF format with white graphics (default is black graphics) for viewing on a black background.
USESIMPLEFONT
In some cases, text is exported as a series of multiple lines which can result in large export files. For example, when true type fonts are used. To export the file using the most basic font type, the command must be used in the following format:
plot SHEE "\\Path\fileName.plt" 'USESIMPLEFONT'
SINGLELINE
By default, exported plot files contain multiple lines to represent thickness. To export the file as single lines, the command must be used in the following format:
plot SHEE "\\Path\fileName.plt" 'SINGLELINE'
