DRAW Reference Manual
Section Planes
: Query Plane
Query Plane
Once a plane has been created, it can be queried:
Q DESC
at Plane level (or at WPOS elements)
The plane referred to by the PLRF attribute of the VSEC can be queried by:
Q PLRF DESC
- at VSEC level
It is possible to query whether a given 3D point is on the retained or discarded side:
Q SIDE @
- at plane level
Q SIDE
/plane_identifier
- from anywhere
Q SIDE
/plane_identifier
E
value
N
value
U
value
from anywhere
In the latter case, only two coordinates need to be given dependent on which orthogonal view direction you are working, for example, for a Plan view only the Easting and Northing are required.
