Frontface Style/Colour. In wireline VIEWs these attributes control the style and colour to be used to represent all edges. All edges display, except for holes that are drawn with a dashed line of the same colour as the FFCOLOUR. Set directly, for example:
Centreline Style/Colour. These attributes control the style and colour to be used for representing centrelines. They are also used for drawing LINE elements of Catalogue Components. When drawing pipework with TUBEF ON, CENTRELINE ON, the centreline is not obscured by the piping Components. (Unlike FFSTYLE, it is not necessary to superimpose two VIEWs with different Styles.
Backface Style/Colour. In hidden line VIEWs, these attributes control the style and colour to be used to draw the rear edges of items (set to OFF by default). Set directly, for example,
Obscured Style/Colour. In global hidden line VIEWs, these attributes control the style and colour used to draw the front-facing edges of items that are otherwise obscured by other objects (set to OFF by default). Set directly, for example,
Obscured and Backface Style/Colour. These behave in the same way as the Obscured Style/Colour but apply only when drawing backface lines that are also obscured. This allows obscured backface lines to be drawn in a different style/colour from other obscured lines, or switched off entirely. If these attributes are not set explicitly, they will match the Obscured style/colour. Once they are set explicitly on a style element, they will have their own values and will need to be maintained independently on that style element. Note that it is only possible to switch the Obscured and Backface style on, if both the general Obscured and Backface styles are also on.
Obscured and Centreline Style/Colour. These behave in the same way as the Obscured Style/Colour but apply only when drawing centrelines that are also obscured. This allows obscured centrelines to be drawn in a different style/colour from other obscured lines, or switched off entirely. If these attributes are not set explicitly, they will match the Obscured style/colour. Once they are set explicitly on a style element, they will have their own values and will need to be maintained independently on that style element. Note that it is only possible to switch the Obscured and Centreline style on, if both the general Obscured and Centreline styles are also on.
P-line Style/Colour. The attribute controls the style and colour to be used to draw p-lines. Set directly, for example:
Member line Style/Colour. These attributes control the style and colour to be used to draw SCTN and GENSEC member lines. Set directly, for example:
Pipe Insulation Style/Colour. These attributes control the style and colour to be used to draw Piping Insulation. Set directly, for example:
