The 2D symbols are generated from templates stored in the DRAW database. These are the Symbol Templates (SYTM) and the
Text Label Templates (TXTM), used for generation of geometric elements or text elements, respectively. Refer to
Basic Hierarchy for a diagram of the DRAW database hierarchy.
The data defining which templates to use for a given design element, and under which circumstances, is stored in the Catalogue database. Several templates can be associated with a design element so that it can be represented differently in different types of Views. The representation of a light fitting, for example, can depend on both the View direction (for example, plan or elevation) and the View classification (for example, Room Design or Cabling).
The design symbols are created as Design Symbol (DESSYM) database elements. DESSYM is a soft-type variant of the Special Label (SLAB) element. The DESSYM elements are added as members of a
Design Symbol Layer (DSLAYE) element, which is a soft-type variant of the Layer (LAYE) element, and is therefore a member of a View. Only one occurrence of DSLAYE is created per View during the UPDATE DESIGN process, the DSLAYE is removed if it subsequently ceases to own any child DESSYMs.
