DIR (Direction) specifies the Looking Direction, down by default. The attribute is set by commands, for example:
The THPO (Through Point) attribute is set to the Design coordinates corresponding to the centre of interest of the view. These are calculated automatically from the VIEW’s related Id List by the AUTO command.
FRPO (the From Point) is the position (in Design coordinates) at which the observer is deemed to be.
The 3D view direction equivalent to 2D Sheet direction can be queried using
where <sheet-dir>is Left, Right, Up or Down. The command gives an error when the VIEW has Perspective or the current database position is not at or below a VIEW.
