DRAW Reference Manual
Draw the Design
Define VIEW Contents Using Id Lists
: Add Elements to 3D View
The DESADD and DESREMOVE commands allow for the addition and removal of Design elements to a 3D view. The syntax is similar to the ADD and REMOVE commands. For example:
DESADD /ZONE.PIPES2-1
DESADD /ZONE.EQUI2-1
DESREMOVE /PIPE2-1-12
DESREM /PUMP2-1-12
The sequence of commands adds elements /ZONE.PIPES2-1 and /ZONE.EQUI2-1 to a 3D View, and removes /PIPE2-1-12 and /PUMP2-1-12. The sequence is normally activated by the interface.
