The endpoint position form of construction derives a position as the endpoint of an identified element (typically a line or an arc). A qualifier can be added if there is any ambiguity about which endpoint is to be used. If there is any ambiguity, and if the qualifier is omitted, then a solution is chosen and returned arbitrarily.
