It is also possible to construct a drafting point position, using commands, for example:
2D_vector specifies an offset position from the
owner origin of the primitive concerned, for example
distance gives a distance and a direction from a point, and can be (in a NOTE or SYTM):
where direction is a 3D, p-point or p-line direction. The distance specified is a Design distance in the current View. The syntax can also be used in most drafting commands, for example, FPT, TPT, CPT, DEFINE, DRAG TO, LENGTH, RADIUS.
