As a primitive element is created, its position is stored separately, with a
reference to the position being stored as the primitive’s PTRF (or PTFA) attribute. An important feature of this system is that if a series of primitives is created, each primitive’s position reference (or
drafting point) is (initially) the same, enabling a series of ‘connected’ shapes to be quickly and easily created. For example, the command sequence
        creates a series of concentric circles. In a similar way, a series of connected straight lines can be created. (A line can have two position references, one at either end; the start position reference of one line can be set equal to the end position reference of the previous line.) A set of primitives connected in this way can be moved as a ‘group’ by using the DRAG command. Refer to
Move Groups of Primitives for further information.
