#Tname is the Template codeword, which enables complex text strings to be defined once in a Text Template (TXTM element). The template can then be referenced from other elements.
name refers to a text template TXTM. For example:
The codeword #T/name must be the only content of the text string. The referenced text string can contain intelligent text codeword strings. However the BTEX attribute of a TXTM cannot itself contain a #T codeword since this can lead to recursion.
