DRAW Reference Manual
Intelligent Text
Access Data from the Design or Catalogue Databases
: Access Data in Catalogue Datasets
Data in a Catalogue Dataset is obtained by a two-part codeword of the general form:
attribute
qualifier
For example:
#PROPERTY^WIDTH
obtain Property value of WIDTH dataset entry
#PRTITLE^WIDTH
obtain Property Title of WIDTH dataset entry
The Property Default (PRDEFAULT) and Property Purpose (PRPURPOSE) settings can be obtained in a similar manner. In each case the first part of the codeword (for example, PROPERTY) can be abbreviated to four characters.
PROPERTY values are evaluated as distances or bores if the PTYPE attribute of the relevant DDTA (or DDAT) element is set to DIST or BORE respectively.
