DRAW Reference Manual
Labels
Autotag
: Define the Autotag Hierarchy and Rules
A typical sequence of commands for setting up an autotagging hierarchy is:
NEW TRLB
NEW TRST
NEW TAGR /TR1
TMRF /LAB1
define Label appearance by setting template reference attribute to point to existing GLAB, SLAB, SYTM or TXTM
IDLN /ID6
define elements to be labelled by setting Id List name attribute to point to existing Id List [or Design] element. [Set to /* by default.]
If the TMRF attribute is set to reference a GLAB or SLAB (as opposed to a TXTM or SYTM) then that GLAB or SLAB must not have been generated by a Tag Rule.
Having constructed the hierarchy and set up the necessary references, the items to be tagged are defined by the TAG command, which applies to those elements defined by the IDLN setting. Examples of the use of the TAG command are:
TAG ALL NOZZ
TAG ALL BRAN MEM TAG (ALL VTWA ALL VFWA ALL VALVE) WI (STYP EQ ’GATE’ AND ABORE GE 80)
TAG ALL WI (CREF NE =0)
The TAG command has the same syntax as the USE
style_name
FOR command. Refer to
Representation Rules
and
Create Labels and Label Text
for further information.
The CRIT attribute for the current tag rule can be set explicitly.
Example:
CRIT ALL BRAN WI (HBOR LE 80 OR TBOR LE 80)
