- sets dimension type to Parallel
- sets dimension type to Chained
DMSP value
- for Parallel Dimensions, sets separation spacing explicitly
- for Parallel Dimensions, sets separation spacing using cursor
TRUN BY value
- for Parallel Dimensions truncates dimension lines by a percentage specified
TRUN TO value
- for Parallel Dimensions truncates dimension lines to a specified value in mm
DTER option
- set dimension line terminator. Options: ARR, OBL, DOT, OFF
FTER option
- set first dimension line terminator. Options: ARR, OBL, DOT, OFF, DEFAULT
- set terminator size to 4mm (default 3mm)
OSHT value
- sets projection line overshoot explicitly
- sets projection line overshoot using cursor
- projection line overshoot defined by a constructed point
PLCL value
- sets projection line clearance explicitly
- sets projection line clearance using cursor
- draw projection lines only
- draw dimension lines only
- draw projection and dimension lines (default)
