- specify the Design item which is referenced for an Angular Dimension - sets DDNM
- creates a Dimension start point with the direction set as the p-point specified - sets DDNM & PPDI, or if direction specified - sets DIR. options: PA, PL, PH, PT, PPoint, IDP, N, S, D, E, W, X, Y, X, HH, HT
TO DIR option
- creates subsequent dimension Point with direction set as p-point specified - sets DDNM & PPDI, or if direction specified - sets DIR
DIM RAD value
- sets the dimension line position as an offset radius from the first Dimension Point - sets DOFF
- changes rotational sense of angular dimensions
