- rearrange Dimension Points into a logical sequence
DIR value
- sets Dimension direction & uses standard AVEVA E3Dâ„¢ direction syntax, or you can use a design p-point direction - sets DIR
PLDI value
- set projection line direction via a direction or angle - sets PLDI
- set dimension line direction to be that calculated from the first & second p-points - sets TLIN true
