- (at Dimension Point level): set dimension text to that of owning Dimension
- DTOF defined by a ‘constructed point’. Refer to Point and Line Construction for further information.
- PTOF defined by a constructed point. Refer to Miscellaneous Text Facilities for further information.
- Change dimension line text to ‘ACCESS SPACE’
- Change projection line text to 'ACCESS SPACE
The first terminator of a truncated dimension can be set independently using the FTER attribute. Refer to Detail Attributes of Linear Dimensions for further information. The first terminator is drawn 25% larger than the remainder.
