Note that OSHT, PLCL and DOFF are given initial default values at
Layer level when the Layer is created. These values are cascaded down to Dimension level when those elements are created subsequently. Following this
initial setting, an attribute set to ‘default’ at Dimension
Point level takes its value from the same attribute of its owning Dimension element (if appropriate).
The Projection Line Clearance (PLCL) is the distance between the dimension point and the projection line at the dimension point end. Negative clearances can be specified. Examples of setting this attribute are:
PLCL can be set at Dimension or Dimension Point level. PLCL set at Dimension level (which becomes the ‘default’ PLCL) applies to all subsequently created Dimension Points. PLCL set at Dimension Point level can only be reset from the same Dimension Point,
not from Dimension level. When setting PLCL with the cursor, the resulting (paper) coordinate that does not lie in the same axis direction as the projection line is ignored. These comments also apply to the OSHT attribute.
The Projection Line Overshoot (OSHT) is the distance by which the projection line ‘overshoots’ the end of the dimension line. Negative overshoots
cannot be specified. Examples of setting this attribute are:
DOFF has a related attribute DPOS - the
Dimension Line Position. DPOS is a fixed 2D paper coordinate through which the dimension line passes. DOFF and DPOS are mutually exclusive: setting one unsets the other. If a dimensioned element is moved the dimension line also moves when DOFF is used; if DPOS is used the dimension line still passes through the same point.
