Data Model
Manu Database
Manu Database Elements
: Connection Weld Element (FAWELD)
Hull Manufacturing Element
Primary Element
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
FabLocation
Fabrication location
tVals
t Values
WBacking
True if backing bar is to be used
WeCom
Weld comment
WeGold
True if golden weld
WeName
Weld name
WeProc
Welding process
WeSusp
Weld end suspension
Wfin
Weld finish
WgAng
Weld groove angle
WGap
Weld Gap
WIntermittent
True if intermittent weld
WIntPitch
Intermittent weld pitch
WIntLength
Intermittent weld length
Wlddia
Diameter (width) for plug/slot welds
WLLen
Leg length of the weld
WLngth
Weld Length
Wndt
No destructive test for the weld
WSLen
Length for slot weld
WSpacer
True if spacer is to be used
WsSusp
Weld start suspension
WStandard
Weld standard
WStdv
Weld standard version
WTest
Test procedure for the weld
Wtorch
Weld torch vector
WType
Weld type
Uuid
Universally unique identifier
Legal Owners:
Connection Between Two Parts Element (FACONN)
Legal Members:
None
