Data Model
Draft Database
Draft Database Elements
: Dimension Point - Before/After Command Element (DPBA)
Draft Dimensioning Element
Attributes:
Name
Name of the element
Ddname
Design element reference
Baindicator
Before/After indicator
Nppt
Ppoint number
Plpen
Projection line pen
Dlpen
Dimension line pen
Ptpen
Projection text pen
Dtpen
Dimension text pen
Plspacing
Projection line text line spacing
Plclearance
Projection line clearance
Dtoffset
Dimension text offset
Ptoffset
Projection line text offset
Overshoot
Overshoot
Justification
Justification
Alignment
Vertical alignment
Pjustification
Projection line text justification
Dfont
Dimension text font
Pfont
Projection line text font
Dtangle
Dimension text angle flag
Ptangle
Projection line text angle flag
Dtcheight
Dimension text character height
Ptcheight
Projection text character height
DTADegrees
Dimension Text Angle Degrees
PTADegrees
Projection Text Angle Degrees
Dmtxt
Dimension text
Pltxt
Gaps
Projection line gap array
Ddnx
Design element as text
DLStyle
Dimension linestyle
DLColour
Dimension line colour
DLnrgb
RGB dimension line colour
PLStyle
Projection linestyle
PLColour
Projection line colour
PLCrgb
RGB projection line colour
DTColour
Dimension text colour
DTxrgb
RGB dimension text colour
PTColour
Projection text colour
PTxrgb
RGB projection text colour
Dlcnmint
Dimension line continuous mode (Default, ByVStyle, Off, On)
Srtpriority
Sorting priority for dimensions
Legal Owners:
Linear Dimension Element (LDIMENSION)
Legal Members:
None
