Data Model
Design Database
Elements in Structural Category
: Structural Section Element (SCTN)
Structural Element
Primary Element
Description:
A SCTN represents a linear component such as a beam, column, strut and so on. It has a uniform cross-section along its length, defined by reference to a Catalogue PROFILE element, while its length is a derived property (not stored in an attribute) which is determined by the Sections start and end positions.
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
StruClassification
Structural Classification
Gtype
Generic type
Number
Number
Desparam
Design parameters
Built
Built/Unbuilt flag
Shop
Shop/Site flag
Bangle
Beta angle
Drnstart
Plane normal at start of SCTN/GENSEC
Drnend
Plane normal at end of SCTN/GENSEC
Posstart
Start point position
Posend
End point position
Joistart
Start joint
Joiend
End joint
Jline
Joining line
Jusline
Justification Pline
Ctystart
Start connection type
Ctyend
End connection type
Srelease
Start releases (packed)
Erelease
End releases (packed)
Grade
Steel grade
Matref
Material reference
Ispec
Insulation spec reference
Firesistance
Fire resistance
WeldDp
Welding depth
PosNo
Position number
ParNam
Part name
Inref
Insulation reference
Spref
Component spec reference
Antype
Analysis type
Drgpriority
Drawing priority (used to determine how to draw SCTN)
Memline
Member line
Orrf
Invfarray
Array of Inventory Items
Uuidia
Universally unique identifier
Tmrref
Template Repeat Element Reference
RepCount
Rule Repeat Counter
Prodrf
Reference to Production Object
Bevcodes
Bevel codes for edges
Legal Owners:
Floor Element (CFLOOR)
Wall Element (CWALL)
Framework Element (FRMWORK)
Subframework Element (SBFRAMEWORK)
Template Element (TMPLATE)
Legal Members:
Compound Fitting Element (CMFITTING)
Design Dataset Element (DDSE)
Fitting Element (FITTING)
Section Distributed Load Element (SDLOAD)
Section Linear Joint Element (SELJOINT)
Secondary Node Element (SNODE)
Section Point Load Element (SPLOAD)
