Data Model
Design Database
Elements in Structural Category
: Primary Node Element (PNODE)
Structural Element
Primary Element
Description:
The PNODE is a fundamental "analytical" point of connection between Sections in an interconnected steelwork structure. Its position is used to define the placing of Sections within the design model and as a reference point for stress analytical calculations on the interconnected structure. Its position is defined relative to the coordinate system of the parent Structure (cf. the Secondary Node element, whose position is defined relative to an owning Section).
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
Number
Number
Nposition
Position in owner
Level
Drawing level
Fixity
Structural fixity
Orrf
Tmrref
Template Repeat Element Reference
RepCount
Rule Repeat Counter
Legal Owners:
Floor Element (CFLOOR)
Wall Element (CWALL)
Framework Element (FRMWORK)
Subframework Element (SBFRAMEWORK)
Template Element (TMPLATE)
Legal Members:
Design Dataset Element (DDSE)
Fixing Element (FIXING)
Nodal Displacement Element (NODISPLACEMENT)
Nodal Load Element (NOLOAD)
Primary Compound Joint Element (PCOJOINT)
Primary Joint Element (PJOINT)
Nodal Release Element (RELEASE)
