Data Model
Design Database
Elements in Structural Category
: Primary Compound Joint Element (PCOJOINT)
Structural Element
Description:
The Primary Compound Joint is used where two or more attached sections are connected at a common Primary Node (representing, for example, a gusset plate). It owns a separate SubJoint for each connection.
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Desparam
Design parameters
Gtype
Generic type
Number
Number
Built
Built/Unbuilt flag
Shop
Shop/Site flag
Delposition
D-position in structure
Opdirection
Origin plane direction
Bangle
Beta angle
Grade
Steel grade
Ispec
Insulation spec reference
Firesistance
Fire resistance
Inref
Insulation reference
Spref
Component spec reference
Orrf
Matref
Material reference
Invfarray
Array of Inventory Items
Legal Owners:
Primary Node Element (PNODE)
Legal Members:
Design Dataset Element (DDSE)
Subjoint Element (SUBJOINT)
Template Element (TMPLATE)
