Data Model
Design Database
Elements in Structural Category
: Floor Element (FLOOR)
Structural Element
Primary Element
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
StruClassification
Structural Classification
Gtype
Generic type
Number
Number
Position
Position
Orientation
Orientation
Desparam
Design parameters
Level
Drawing level
Obstruction
Obstruction level
Built
Built/Unbuilt flag
Shop
Shop/Site flag
Spref
Component spec reference
Matref
Material reference
Grade
Steel grade
Ispec
Insulation spec reference
Firesistance
Fire resistance
Orrf
Invfarray
Array of Inventory Items
Uuidia
Universally unique identifier
Tmrref
Template Repeat Element Reference
RepCount
Rule Repeat Counter
Prodrf
Reference to Production Object
Excess
Excess
Bevcodes
Bevel codes for edges
Legal Owners:
Floor Element (CFLOOR)
Framework Element (FRMWORK)
Subframework Element (SBFRAMEWORK)
Template Element (TMPLATE)
Legal Members:
Compound Panel Fitting Element (CMPFITTING)
Panel Cofitting Element (COFITTING)
Design Dataset Element (DDSE)
Negative Box Element (NBOX)
Negative Cone Element (NCONE)
Negative Circular Torus Element (NCTORUS)
Negative Cylinder Element (NCYLINDER)
Negative Dish Element (NDISH)
Negative Polyhedron Element (NPOLYHEDRON)
Negative Pyramid Element (NPYRAMID)
Negative Revolution Element (NREVOLUTION)
Negative Rectangular Torus Element (NRTORUS)
Negative Slope Bottom Cylinder Element (NSLCYLINDER)
Negative Snout Element (NSNOUT)
Negative Rectangular Extrusion Element (NXTRUSION)
Panel Linear Joint Element (PALJOINT)
Panel Fitting Element (PFITTING)
Panel Loop Element (PLOOP)
