Data Model
Design Database
Elements in Structural Category
: Compound Fitting Element (CMFITTING)
Structural Element
Primary Element
Description:
A CMFI can be used to represent a penetration at which one or more elements (Pipes or Sections) pass through a hole in a Section. The position of each individual penetrating item is represented by a Subfitting (SBFI) element owned by the CMFI; the CMFI is primarily an administrative element used to position a group of SBFI. A CMFI is positioned along the Z axis of its owning Section, in the same way as a Secondary Node.
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
Desparam
Design parameters
Gtype
Generic type
Number
Number
Zdistance
Position in section
Built
Built/Unbuilt flag
Shop
Shop/Site flag
Posline
Positioning line
Delposition
D-position in structure
Bangle
Beta angle
Grade
Steel grade
Ispec
Insulation spec reference
Firesistance
Fire resistance
Inref
Insulation reference
Spref
Component spec reference
Orrf
Invfarray
Array of Inventory Items
Matref
Material reference
Tmrref
Template Repeat Element Reference
RepCount
Rule Repeat Counter
Legal Owners:
Structural Section Element (SCTN)
Structural Wall Element (STWALL)
Legal Members:
Design Dataset Element (DDSE)
Nodal Displacement Element (NODISPLACEMENT)
Nodal Load Element (NOLOAD)
Nodal Release Element (RELEASE)
Subfitting Element (SBFITTING)
Template Element (TMPLATE)
