Data Model
Design Database
Elements in Primitive Hole Category
: Negative Revolution Element (NREVOLUTION)
Primitive Hole Element
Description:
The Negative Solid of Revolution represents any negative shape which can be generated by sweeping a constant cross-section profile through an angle about an axis. The profile is represented by a LOOP, in the same way as for a Negative Extrusion, but in this case the profile is swept about an axis rather than along a linear path. The swept angle must be in the range -360 to +360 degrees, 360 degrees giving a volume which is axially symmetrical.
Attributes
Name
Name of the element
Purpose
Description code word
Position
Position
Orientation
Orientation
Level
Drawing level
Obstruction
Obstruction level
Angle
Angle
Orrf
Tmrref
Template Repeat Element Reference
RepCount
Rule Repeat Counter
Legal Owners:
Box Element (BOX)
Bent Plate Element (BPANEL)
Cone Element (CONE)
Circular Torus Element (CTORUS)
Cylinder Element (CYLINDER)
Dish Element (DISH)
Extrusion Element (EXTRUSION)
Floor Element (FLOOR)
Wall Element (GWALL)
Panel Element (PANEL)
Polyhedron Element (POLYHEDRON)
Pyramid Element (PYRAMID)
Revolution Element (REVOLUTION)
Rectangular Torus Element (RTORUS)
Screed Element (SCREED)
Slope Bottom Cylinder Element (SLCYLINDER)
Snout Element (SNOUT)
Template Element (TMPLATE)
Terrain Primitive Holder Element (TRNPRI)
Legal Members:
Loop Element (LOOP)
