Data Model
Design Database
Elements in Primitive Category
: Snout Element (SNOUT)
Primitive Element
Attributes:
Name
Name of the element
Purpose
Description code word
Position
Position
Orientation
Orientation
Level
Drawing level
Obstruction
Obstruction level
Dtop
Top diameter
Dbottom
Bottom diameter
Xoffset
X-offset
Yoffset
Y-offset
Height
Height
Orrf
Tmrref
Template Repeat Element Reference
RepCount
Rule Repeat Counter
The origin of the Snout is at the mid-point of the line joining the centres of the top and bottom surfaces and the Z-axis is normal to the top and bottom surfaces.
Legal Owners:
Equipment Element (EQUIPMENT)
Cable Junction Box Element (JNTBOX)
Pipe Track Element (PTRACK)
Pulling Pit Element (PULLPIT)
Structure Element (STRUCTURE)
Subequipment Element (SUBEQUIPMENT)
Substructure Element (SUBSTRUCTURE)
Sub Volume Model Element (SVOLMODEL)
Template Element (TMPLATE)
Terrain Primitive Holder Element (TRNPRI)
Volume Model Element (VOLMODEL)
Legal Members:
Negative Box Element (NBOX)
Negative Cone Element (NCONE)
Negative Circular Torus Element (NCTORUS)
Negative Cylinder Element (NCYLINDER)
Negative Dish Element (NDISH)
Negative Polyhedron Element (NPOLYHEDRON)
Negative Pyramid Element (NPYRAMID)
Negative Revolution Element (NREVOLUTION)
Negative Rectangular Torus Element (NRTORUS)
Negative Slope Bottom Cylinder Element (NSLCYLINDER)
Negative Snout Element (NSNOUT)
Negative Rectangular Extrusion Element (NXTRUSION)
