Data Model
Design Database
Elements in Primitive Category
: Drawn Line Element (DRAWING)
Primitive Element
Description:
DRAWING is an element which may be used to produce a symbol or shape on a drawing not normally catered for elsewhere. If, for example, it were necessary to show a company name in large letters painted on the side of a tank, the letters could be built up as DRAWI elements which would be members of the EQUIP containing the tank. Commonly used to show the centreline of a beam or column.
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
Position
Position
Orientation
Orientation
Level
Drawing level
Skey
Symbol key
Lissue
True if drawing has been issued
Wmaximum
Maximum weld number in current spool drawing
Pmaximum
Maximum part number in current spool drawing
Smaximum
Maximum spool number in current spool drawing
Jmaximum
Maximum joint number in current spool drawing
Rev
Pipe Revision number
Splprefix
Spool number prefix
Orrf
The following graphics displays lines and curves drawn between Points(P), Tangent Points(T) and Invisible Points(I) for Boundaries and Drawings.
Legal Owners:
Conveyor Element (CONVEYOR)
Equipment Element (EQUIPMENT)
Cable Junction Box Element (JNTBOX)
Pipe Track Element (PTRACK)
Pulling Pit Element (PULLPIT)
Ref Data Group Element (REFDAT)
Site Element (SITE)
Structure Element (STRUCTURE)
Subequipment Element (SUBEQUIPMENT)
Substructure Element (SUBSTRUCTURE)
Sub Volume Model Element (SVOLMODEL)
Template Element (TMPLATE)
Volume Model Element (VOLMODEL)
Zone Element (ZONE)
Legal Members:
Invisible Point Element (IPOINT)
Point Element (POINT)
Tangent Point Element (TANPOINT)
Text Element (TEXT)
