Data Model
Design Database
Elements in Piping Major Items Category
: Pipe Element (PIPE)
Pipe Element (PIPE)
Piping Major Items Element
Primary Element
Description:
The PIPE is an administrative owner of one or more two-ended BRANCHes. Usually a PIPE will include a principle BRANCH routed between two NOZZLES, with subsidiary BRANCHes for control loops, bypasses to spare pumps and so on. The PIPE contains functional attributes of three types:
Those which are used directly from the PIPE element (by modules such as ISODRAFT) as a collective attribute for all the BRANCHes in the PIPE, for example: Pipe Spec (PSPE).
Those which have no direct significance at PIPE level, but which are cascaded downwards to member BRANCHes (or even Components) where they perform a particular function, for example: TEMPERATURE - only used by Branch for insulation, stressing and so on.
Information attributes that can only be reported on, for example: BUILT.
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
Built
Built/Unbuilt flag
Shop
Shop/Site flag
Isohidden
Isohidden flag
Bore
Bore
Temperature
Temperature
Pressure
Pressure
TPressure
TestPressure
Pspec
Pipe specification
Ispec
Insulation spec reference
Tspec
Tracing spec reference
Matref
Material reference
Fluref
Fluid reference
Casref
Case reference
Ccentre
Cost centre
Cclass
Cost class
Linetype
Line type
Erection
Erection class
Rev
Pipe Revision number
Safclass
Safety class
Duty
Duty
Dscode
Design code
Ptspec
Paint specification
Inschedule
Inspection schedule
Skey
Symbol key
Lissue
True if drawing has been issued
Wmaximum
Maximum weld number in current spool drawing
Pmaximum
Maximum part number in current spool drawing
Smaximum
Maximum spool number in current spool drawing
Jmaximum
Maximum joint number in current spool drawing
Drrf
Old spooler drawing reference
Cdrg
Isodraft Compipe: Drawing number
Cnumber
Isodraft Compipe: Line number
Carea
Isodraft Compipe: Area
Splprefix
Spool number prefix
Orrf
BendMacReference
Bending Machine reference
Uuidia
Universally unique identifier
Rlstored
Array of ROUTER saved rules
Deldsg
Delivery Designation flag
Farea
Construction area
Fpline
Process line number
Fdrawing
Isometric drawing number
Frevision
Isometric drawing revision
Frdrawing
Reference drawings
Fstatus
Fstatus
PLANU
Planning Unit
JNTC
Joint Code
WLDC
Weld Code
HEATT
Heat Treatment
Mdsysf
Reference Array of Model and Design Elements
Inprtref
Inside paint reference
Ouprtref
Outside paint reference
Sloreference
Pipe slope reference
Legal Owners:
Conveyor Element (CONVEYOR)
Zone Element (ZONE)
Legal Members:
Branch Element (BRANCH)
Pipe Piece List Element (PPLIST)
Pipe Spool List Element (PSLIST)
Restraint Element (RESTRAINT)
Text Element (TEXT)
