Data Model
Design Database
Elements in Piping Fabrication Category
: Fabrication Machine Extrusion Dimension Element Element (FMEDIM)
Piping Fabrication Element
Attributes:
Name
Name of the element
Description
Description of the element
OD
Outer Diameter
Extbod
Extrusion branch outside diameter
Matref
Material reference
WThickness
Wall thickness
Exteab
Minimum distance from centre of an extrusion to next bend
Exteak
Minimum distance from an extrusion to the pipe end
Exteah
Extrusion collar height (from the top of tube to the end of collar)
Extehe
Height of extrusion machine
Extant
Tolerance angle
Legal Owners:
Fabrication Machine Extrusion Element (FMEXTR)
Legal Members:
None
