Data Model
Design Database
Elements in Equipment Category
: Equipment Element (EQUIPMENT)
Equipment Element
Primary Element
Description:
The EQUIPMENT element represents process vessels, storage vessels, heat exchangers, pumps and any other predefined item that is part of the plant. The unique feature of this element is that it may own NOZZLEs in addition to the normal primitive shapes. Pipework can be connected to the Nozzles, thus making EQUIPMENTs intrinsic to the process system.
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
Number
Number
Area
Area
Usrweight
User entered weight value
Usrwweight
User entered wet weight value
Usrcogravity
User centre of gravity position
Usrwcogravity
User wet centre of gravity position
Position
Position
Orientation
Orientation
Desparam
Design parameters
Built
Built/Unbuilt flag
Ispec
Insulation spec reference
Uwmtxt
User weight Manager text
Dscode
Design code
Ptspec
Paint specification
Inschedule
Inspection schedule
Skey
Symbol key
StlRef
Steel Reference
Orrf
Stmf
Template selection pointer
Invfarray
Array of Inventory Items
Uuidia
Universally unique identifier
Propst
Property set reference array
Spref
Component spec reference
Fstatus
Fstatus
Mdsysf
Reference Array of Model and Design Elements
Inprtref
Inside paint reference
Ouprtref
Outside paint reference
Legal Owners:
Conveyor Element (CONVEYOR)
Zone Element (ZONE)
Legal Members:
Aid Group Element (AIDGROUP)
Box Element (BOX)
Bent Plate Element (BPANEL)
Cone Element (CONE)
Circular Torus Element (CTORUS)
Cylinder Element (CYLINDER)
Design Dataset Element (DDSE)
Dimension Group Element (DIMGROUP)
Dish Element (DISH)
Drawn Line Element (DRAWING)
Electrical Connection Element (ELCONN)
Equipment Component Element (EQUCOM)
Extrusion Element (EXTRUSION)
Equipment Load Point Element (LOAPOINT)
Nozzle Element (NOZZLE)
Panel Element (PANEL)
Polyhedron Element (POHEDRON)
Polyhedron Element (POLYHEDRON)
Penalty or Preferred Volume Element (PVOLUME)
Pyramid Element (PYRAMID)
Revolution Element (REVOLUTION)
Routing Plane Element (RPLANE)
Rectangular Torus Element (RTORUS)
Slope Bottom Cylinder Element (SLCYLINDER)
Snout Element (SNOUT)
Subequipment Element (SUBEQUIPMENT)
Text Element (TEXT)
Template Element (TMPLATE)
