Data Model
Design Database
Elements in Accommodation Category
: Open Space Element (OPENSPACE)
Accommodation Element
Primary Element
Attributes
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
Area
Area
Number
Number
Position
Position
Orientation
Orientation
Heidefault
Default Height value
NAngle
North angle
FlrHeight
Floor Height
XYOffset
XY offset
AreaReference
Area reference
Temperature
Temperature
MaxTemperature
Maximum Temperature
MinTemperature
Minimum Temperature
Humidity
Design Humidity
MaxHumidity
Maximum Humidity
MinHumidity
Minimum Humidity
MaxWater
Maximum Water Level
AirChangeRate
Air Change Rate
Occupancy
Occupancy
Lighting
Lighting requirements
FireRating
Fire rating
Firesistance
Fire resistance
MaxArea
Maximum area
MinArea
Minimum area
MaxVolume
Maximum Volume
MinVolume
Minimum Volume
ColSchema
Color Schema
DFlrType
Default Floor Type
DFlrCode
Default Floor Code
LabOffset
Label offset
Legal Owners:
Building Block Element (BBLOCK)
Building Level Element (BLEVEL)
Room Element (ROOM)
Legal Members:
Access Point Set Element (ACCSET)
Area Definition Element (AREADEF)
Boundary Line Element (BNDLIN)
Detail Group Element (DETGRP)
Inventory List Element (INVLST)
Ref Data Group Element (REFDAT)
Restricted Area Element (RSTAREA)
Routing Volume Element (RUTVOLUME)
Boundary Element Set Element (SPBSET)
Stairwell Element (STRWELL)
