Data Model
Introduction to Attributes
List of All Attributes
: Attribute W
Attribute W
Attribute Name
Data Type
Qualifier
Description
W
real
Position westing
WALLTH
real
Tube wall thickness
WAMA
real
Maximum water level
WANS
word(100)
Word answers
WASHRH
string(32)
Detailing Bolt Set Head-Side Washer
WASHRN
string(32)
Detailing Bolt Set Nut-Side Washer
WATERT
logical
Water Tight
WATTIM
real
Water cleaning time
WBACK
logical
True if backing bar is to be used
WBORE
real
Bore on IWELD/RWELD
WCANG
real
Weld connection angle
WCCAS
integer
Welding constant contour (arrow side)
WCCOS
integer
Welding constant contour (other side)
WCHAR
integer
Detailing Weld Characteristic
WCLOS
logical
Closure weld
WCMNT
string(32)
Weld Comment
WCOM
string(26)
Weld comment
WDBNA
string
Working DB name
WDESP
word(100)
Design parameters as words
WDIA
string(1000)
Wind diameter modulus
WECOM
string(256)
Weld comment
WEFA
real
Weight multiplier
WEGOLD
logical
True if golden weld
WEIG
real(3)
Weighting value
WELCON
word
Welding machine connection type
WELDDP
real
Welding depth
WELDMC
element
Welding Machine Reference
WELDTY
word
Weld Type
WELMAC
real
Minimum tube length for machine welding
WELMAN
real
Minimum tube length for manual welding
WELORB
real
Minimum tube length for orbital welding
WENAM
string(256)
Weld name
WEPROC
string(256)
Welding process
WESUSP
real
Weld end suspension
WEXPTX
string(32)
Welding Fish Tail: Explanation text
WFIN
string(256)
Weld finish
WFISTA
string(32)
Welding Fish tail: Additional Text 1
WFISTB
string(32)
Welding Fish tail: Additional Text 2
WFISTC
string(32)
Welding Fish tail: Additional Text 3
WFLELM
element
Reference to Workflow Element
WFRDBL
real(5)
Detailing Weld Free Doubles
WFTXA
string(32)
Welding Free text 1
WFTXB
string(32)
Welding Free text 2
WFTXC
string(32)
Welding Free text 3
WFTXD
string(32)
Welding Free text 4
WGANG
real
Weld groove angle
WGAP
real
Weld Gap
WGNAS
integer
Welding symbol ID (arrow side)
WGNOS
integer
Welding symbol ID (other side)
WGOLD
logical
Golden Weld
WGROUP
integer
Weld Grouping Option
WHOLEC
real
Array of Whole Cells
WIANG
real
Weld inclination angle
WIDARR
real(10)
Width array
WIDT
real
Width
WIFA
real
Wind multiplier
WIMAS
logical
Intermittent weld (arrow side)
WIMOS
logical
Intermittent weld (other side)
WINDAS
string(32)
Welding Index (Arrow Side)
WINDOS
string(32)
Welding Index (Other Side)
WINT
logical
True if intermittent weld
WINTL
real
Intermittent weld length
WINTP
real
Intermittent weld pitch
WIRESZ
string(120)
Wire size
WISYM
integer
Welding Process symbol number
WJPOS
pos
Implied weld position
WJUSL
word
Wall Justification Line
WLDAAS
real
Weld chamfer angle arrow side
WLDAOS
real
Weld chamfer angle (other side)
WLDBAS
integer
Weld Backing (arrow side)
WLDBOS
integer
Weld Backing (other side)
WLDC
integer
Weld Code
WLDCAS
real
Weld width (arrow side)
WLDCOS
real
Weld width (other side)
WLDDAS
real
Weld Diameter (arrow side)
WLDDIA
real
Diameter(width) for plug/slot welds
WLDDOS
real
Weld diameter (other side)
WLDEAS
real
Weld thickness (arrow side)
WLDEOS
real
Weld thickness (other side)
WLDFAS
integer
Welding Finish (arrow side)
WLDFOS
integer
Welding Finish (other side)
WLDHAS
integer
Welding Spacer (arrow side)
WLDHOS
integer
Welding Spacer (other side)
WLDINF
integer
Welding information
WLDLAS
real
Weld segment length (arrow side)
WLDLOS
real
Weld segment length (other side)
WLDN
integer
Weld number
WLDNAS
integer
Number of weld segments (arrow side)
WLDNDT
logical
Welding NDT (Non-Destructive Testing)
WLDNOS
integer
Number of weld segments (other side)
WLDP
string(4)
Weld number prefix
WLDPOS
string(26)
Welding position
WLDRAS
real
Weld chamfer Gap (arrow side)
WLDREF
element
integer
Return reference from Ppoint or WELD to IWELD or RWELD element
WLDRND
logical
Flag weld all round
WLDROS
real
Weld chamfer Gap (other side)
WLDSAS
real
Weld chamfer depth (arrow side)
WLDSOS
real
Weld chamfer depth (other side)
WLDTAS
integer
Weld process number (arrow side)
WLDTHY
real
Weld material thickness (Y direction)
WLDTHZ
real
Weld material thickness (Z direction)
WLDTOS
integer
Weld process number (other side)
WLDTYP
integer
Welding Element Type Number
WLDVAS
real
Weld segment offset (arrow side)
WLDVOS
real
Weld segment Offset (other side)
WLDZAS
real
Weld leg length (arrow side)
WLDZOS
real
Weld leg length (other side)
WLEGL
real
Weld leg length
WLEGTX
string(32)
Welding legend text
WLEN
real
Weld length
WLLEN
real
Leg length of the weld
WLNGTH
real
Weld Length
WMAX
integer
Maximum weld number in current spool drawing
WMDREF
element
Reference to weld master data
WNAM
string(26)
Weld name
WNAMAS
string(32)
Weld Name (arrow side)
WNAMOS
string(32)
Weld Name (other side)
WNCAT
string(32)
Welding NDT Category name
WNDT
string(256)
No destructive test for the weld
WNDTN
string(32)
Welding NDT type name
WNDTP
real
Welding NDT percentage
WNLAY
integer
Number of weld layers
WNPROC
string(32)
Welding NDT process name
WNTHK
string(32)
Weld Name Thickness
WORI
ori
World orientation
WORPOS
pos
World position
WPAR
word(100)
Parameters as a word
WPDAS
real
Weld segment distance (arrow side)
WPDOS
real
Weld segment distance (other side)
WPLEN
real
Weight per length
WPOST
string(32)
Weld mark text
WPRE
real
Wind pressure
WPROC
string(26)
Welding process
WRANG
real
Weld rotation angle
WRKMRK
string(30)
Working Revision Indicator String
WRKSEQ
string(256)
Working sequence
WRKSHR
integer
Work Share
WSHOP
logical
Weld shop/site flag on IWELD/RWELD
WSLEN
real
Length for slot weld
WSPACE
logical
True if spacer is to be used
WSPEC
element
Weld specification on IWELD/RWELD
WSPROC
string(26)
Welding standard process
WSSAS
real
Weld penetration depth (arrow side)
WSSOS
real
Weld penetration depth (other side)
WSSUSP
real
Weld start suspension
WSTAND
string(256)
Weld standard
WSTDV
string(256)
Weld standard vesrion
WTCOM
string(300)
Weld table comment
WTEREF
element
integer
Wall thickness element reference
WTEST
string(256)
Test procedure for the weld
WTHICK
real
Wall thickness
WTHREF
element
Wall thickness table reference
WTOL
string(1000)
Wall thickness tolerance / Weight tolerance
WTORCH
dir
Weld torch vector
WTPROC
string(26)
Welding test procedure
WTRANS
real(12)
Transformation matrix to world
WTSTAT
string(26)
Weld table status
WTYPE
word
Weld type
WUNIQ
logical
Welding Element Unique Flag
WVOL
real(6)
Enclosing box volume in world coordinates
WVTAS
integer
Weld type (arrow side)
WVTOS
integer
Weld type (other side)
