Data Model
Introduction to Attributes
List of All Attributes
: Attribute U
Attribute U
Attribute Name
Data Type
Qualifier
Description
U
real
Position upping
UAEXSS
real
User Excess Arrive
UALIAS
string(10)
Alias of the standard user
UALL
logical
UALL
UAREA
real
Used area
UAXIS
dir
uAxis
UBULG
real
Used bulge factor for curve geometry
UCASES
logical
Set true to allow Engineering cases
UCAT
string(120)
Category on forms
UCLONE
logical
Propagate to linked elements
UCOD
integer
Units code
UCODB
integer
Units code bore
UCODD
integer
Units code distance
UCONN
logical
True if the element referenced by UDA value should appear as a connection
UCURTYP
word
Used curve type
UCUTDI
dir
Upper Extension Cutting Direction
UCVAL
element(500)
referenced to controlling UVALID
UDACPY
element
UDA copy
UDALIS
word(2000)
List of UDAs
UDASET
word(2000)
List of UDAs set
UDATLS
word(200)
List of attributes for UDET
UDESC
string(4800)
Full description of the element
UDETCHECK
string(120)
Report from UDET check on element
UDHLIST
word(120)
Attributes hidden on elements of this user-defined element type
UDIRECTION
dir
Up axis direction
UDMLIST
word(2147483647)
List of allowed member types
UDNA
string(120)
User defined name
UDOLIST
word(2147483647)
List of allowed owner types
UDPEND
word(100)
list of attributes that this attribute depends on
UDPMEM
word(500)
Possible type members for a UDET
UDPOWN
word(500)
Possible owners for a UDET
UDPSFG
string(100)
Name of PML function used for value calculation. Function should take single parameter of DBREF type.
UDPSFS
string(100)
Name of PML function used for SET value. Function should take parameters of DBREF type and a value.
UDTABL
logical
Determines if UDA is to be indexed in a table for fast access
UDTEX
integer(500)
user Defined Type Group Expression
UDTGS
word(500)
User Defined Group Types
UEEXSS
real
User End Excess
UEXMAX
integer(500)
Expression defining the maximum value
UEXMIN
integer(500)
Expression defining the minimum value
UEXTNS
real
Upper Extension Length
UGOING
real(10)
Upper Tread Going
UHIDE
logical
Set true to hide attribute on forms
UHYPER
logical
Set true to treat attribute value as a named link to an external resource
UIWE
string(1000)
Unit insulation weight
UKEY
integer
UDA key - internal unique system identifier
UKEYFR
integer
Number of free UKey values available
ULEN
integer
Length of data or text
ULVOPT
logical
Determines if UDA valid values or range limit is optional
UMAX
real
Maximum value
UMDBRE
logical
Determines if User-MDB association is restrictive
UMIN
real
Minimum value
UMINLE
integer
Minimum length for text or word
UNAM
string(12)
Name of user
UNDERL
logical
Underling flag
UNODUP
logical
Set false to dissallow duplicate values in the array
UNRESO
logical
attr
T/F on attributes that are unresolved references
UNTORD
integer
Unit order
UNTSTDIMENSION
string(100)
Unit set dimension
UNTSTSYSTEM
string(20)
Unit set system
UPDCB
string(500)
ADP update callback
UPGDDB
integer
Upgrade number for DB
UPLLEN
real
Used raw plate length
UPPING
pos
Upping part expressed as a position
UPPREF
element
References to upper exit level
UPRLEN
real
Used profile length
UPROMPT
string(40)
Textual prompt to display to the user
UPROTE
logical
Set true to disallow viewing the attribute in a protected database
UPSEUD
logical
Set true to calculate attribute value rather than store it in a database. User code must be provided
URADI
real
Used radius for curve geometry
UREF
element
Units reference
URISE
real(10)
Upper Tread Rise
URL
string(1024)
URL
USCCOG
pos
User derived centre of gravity position
USCLHI
element(5000)
Elements in descendant hierarchy claimed to this user
USCWCO
pos
User derived wet centre of gravity position
USCWEI
real
Derived value for user weight
USCWWE
real
Derived value for user wet weight
USECAP
logical
Capital Letter Usage Indicator
USECDE
string(120)
Text storing user code for cable
USEF
element
User reference
USEFED
real
User defined feed excess
USEHDR
logical
Header Usage Indicator
USERC
string(120)
User name of user claiming element
USERLS
element(2000)
List of USERs belonging to TEAM
USERM
string(120)
attr
User making last modification
USESS
string(640)
integer
User creating session
USHVV
element
UDA shared valid value
USNCLH
element(5000)
Elements in descendant hierarchy not claimed to this user
USRCOG
integer(500)
User centre of gravity position
USRLI
element(50)
Valid users for given user login
USRMDB
element(100)
MDBs that a user may select from. If unset, then there is no restriction.
USRWCO
integer(500)
User wet centre of gravity position
USRWEI
integer(500)
User entered weight value
USRWWE
integer(500)
User entered wet weight value
USUVAL
string(50)
Unit for Unit Set
USYSTY
word
Name of the system attribute
UTCSES
logical
integer
True if the session date is a calculated local date
UTCSTP
logical
True if the stamp date is a calculated local date
UTCSWT
logical
True if System outputs UTC based Session Date Times
UTEAMS
element(500)
Teams that will see a hidden attribute
UTYP
word
Type of the value. INT, REAL, TEXT, REF, LOG, WORD, POS, DIR, ORI or DATE
UUID
string(36)
Universally unique identifier
UUIDAR
integer(4)
Universally unique identifier, stored array
UUIDIA
integer(4)
UUIDREF
element(500)
word
Universally unique identifier references
UUNI
string(80)
Dimension of attribute value (bore/distance/text)
UVVAL
string(500)
Valid value for UDA
UVVFER
word
Attribute to follow to get UDA valid values filtering element
UWEI
string(1000)
Unit pipe weight
UWGHT
real
Used weight
UWIDTH
real
Used width
UWMTXT
string(120)
User weight Manager text
UWP
pos
Upper Working Point
