Data Model
Introduction to Attributes
List of All Attributes
: Attribute T
Attribute T
Attribute Name
Data Type
Qualifier
Description
TAACTI
logical
Task Active
TAASTA
element
word, integer
Assigned Task Reference
TAATCT
integer
word
Assigned Tasks Count
TAATDS
string
word, integer
Assigned Task Description
TAATKS
element(500)
word
Assigned Tasks
TAATNA
string(200)
word
Assigned Task Name
TAATNB
integer
word, integer
Assigned Task Number
TAATNS
string
word
Assigned Task Names
TAATSN
string
word, integer
Assigned Task Status Name
TABANS
real(10)
Tabular answers
TABCLN
!UNKNOWN(10)
Tabite Class Name
TABREF
element(100)
Tabite reference
TACOL
string(120)
Task Colour
TACORO
real(50)
Task Connection Route
TAFILT
string(120)
Task Filter
TAFONT
string(120)
Task Font
TAGCD
integer
Tag code
TAGCDS
integer(25)
Tag codes
TAGNMS
integer(25)
Tag numbers
TAGNUM
integer
Tag number
TAHEIG
real
Task Height
TAILH
real
Tail duct height
TAILW
real
Tail duct width
TAISAS
logical
word
True if element is assigned to a task
TALOSE
string(32)
Task Logic Selection
TANAME
string(80)
Task Item Name
TANGLE
real
Tile Angle
TANGOF
real
Tangent offset
TANS
string(257)
Text answer for text styp in spec
TANSCT
integer
Task Name Space Count
TANSNA
string(200)
integer
Task Name Space Name
TANSNS
string
word
Task Name Space Names
TAPOS
real(2)
Task Position
TAPREF
element
Tapping table reference
TARF
element
Target reference
TASKID
string(50)
Task ID
TASKTY
string(32)
Task Type
TASTDS
string
word
Task Status Description
TASTNA
string
word
Task Status Name
TASTNB
integer
word
Task Status Number
TASTVA
element
word
Task Status Value Reference
TATCOL
string(120)
Task Text Colour
TATYIN
string(500)
Task Input Type
TATYOU
string(500)
Task Output Type
TATYPE
string(10)
Text answer type
TATYTR
string(32)
Task Treated Type
TAWID
real
Task Width
TBID
integer
Tribon ID
TBNAME
string(25)
TbName
TBOR
real
Tail bore
TCAT
element
Trace catalogue reference
TCDD
string(250)
word
Current design property default value
TCDP
string(250)
word
Current design property value
TCOD
string
Hashed origin code
TCON
word
Tail connection type
TCORRO
real
Tail Corrosion
TCREF
element(100)
Tail connections
TCTL
real
True cut length
TDATUM
pos
Definition of a specific point on earth
TDEF
string(257)
Text default for text styp in spec
TDET
element
Trace detail text reference
TDIR
dir
Tail direction
TDMF
element(2)
ISODRAFT Reference Dimension attribute
TDMT
word(2)
TDPR
real
word
Template design dataset property
TDRT
string(2000)
Trace detail RTEXT
TDST
string(2000)
Trace detail STEXT
TDTT
string(2000)
Trace detail TTEXT
TEAMLS
element(1000)
List of TEAMs to which USER belongs
TEAMSTATUS
word
Access Control team status
TEMF
element
Team reference
TEMP
real
Temperature
TEND
string
Connection at other end of TREF (HEAD or TAIL)
TEQDES
string(120)
To Equipment Description
TESTEV
logical
Result of constraint test evaluation
TESTXP
integer(500)
Logical Expression
TEXIST
logical
True if component has TUBI. Always true for offline bends.
TEXLEN
integer
Length of text
TEXTD
string(120)
Generic Text Data Storage
TFDP
element
word
TGEOM
logical
True if component has TUBI geometry
TGHETP
string(20)
Type of Tightness code
TGHTYP
integer
Type of Tightness
TGRA
real
Pipework temperature gradient
THERMA
string(26)
Thermal category
THICKNESS
real
Thickness
THPO
pos
Point through which viewing
THSIZE
real(4)
Thumbnail size
TIERHE
real(15)
Heights of trays measured from path
TIGHOL
logical
Tight hole
TIMEEND
integer
End time of COMMS window
TIMEINTERVAL
integer
COMMS retry time interval
TIMEOUTNUMBER
integer
COMMS max retry count
TIMER
string(120)
Frequency of DB propagation
TIMESTART
integer
Start time of COMMS window
TIMFAC
real
Pathtime time factor
TIMPET
string(15)
Time factor pre text
TIMPOT
string(15)
Time factor post text
TITL
string(1000)
Title
TLCONN
element(500)
List of elements connected to branch tail
TLIN
logical
True length indicator
TLREF
element(500)
List of attachment connected to attachment
TLVBEV
real
Profile trace length, V bevel
TLXBEV
real
Profile trace length, X bevel
TLYBEV
real
Profile trace length, Y bevel
TMAT
element
Trace material text reference
TMAV
real
Average temperature
TMDWG
string(120)
AutoCAD template name
TMMA
real
Maximum temperature
TMMI
real
Minimum temperature
TMPLTF
string(2000)
Datasheet Template filename
TMPR
element
Template reference from SPCO
TMRF
element
Template reference
TMRFSE
element
Secondary template reference
TMRMASTER
element
Template Repeat Master Duplicate Element
TMROWNER
element
Template Repeat Owning Element
TMRREF
element
Template Repeat Element Reference
TMRRULE
integer(500)
Template Repeat Rule
TMRXREF
element(500)
Return reference from TMRREL element to repeat elements
TMSAAA
logical
Automatic Admin Approval
TMSADP
logical
Automatic Discipline Pulldown
TMSDIF
element
TMS Discipline
TMSPRJ
logical
Flag to notify if this is a TMS Project
TMXT
string(2000)
Trace material XTEXT
TMYT
string(2000)
Trace material YTEXT
TMZT
string(2000)
Trace material ZTEXT
TNVOL
real
Terrain net volume
TODATA
string(120)
To check the mode of creation for to references
TOODIR
integer
Tool path direction
TOPCUT
real
Top Stile Cut Distance
TOPOLOGY
string(120)
Branch topology
TOPSTR
real
TOP Stringer Gap
TOTALT
real
Total machine time for a nested plate
TOTLAB
real
Total label pathtime
TOTLEN
real
Total manual length
TOTT
real(2)
Total pathtime
TOTTI
real(2)
Total pathtime, I-bevel
TOTTX
real(2)
Total pathtime, X-bevel
TOTTY
real(2)
Total pathtime, Y-bevel
TPAR
real(30)
Trace catalogue component parameters
TPAREA
string(120)
Templated Project Area Name
TPDISC
string(120)
Templated Project Discipline Name
TPEN
integer
Text pen
TPLFRR
element(10000)
integer
Topology references - from
TPLFRT
integer(10000)
element
Topology reference types - from
TPLPAR
real(50)
Template parameters
TPLTOR
element(10000)
integer
Topology references - to
TPLTOT
integer(10000)
element
Topology reference types - to
TPLTYP
string(25)
Template type
TPON
integer
TO port number
TPOS
pos
Tail position
TPOSE
real
Easting of tail position
TPOSN
real
Northing of tail position
TPOSTO
real
Top post offset
TPOSU
real
Upping of tail position
TPREF
element
Tail point reference
TPRESS
real
TestPressure
TPVAL
string(1000)
Task parameter name
TQUAL
string(257)
Text qualifier in spec or sele
TQUES
string(257)
Text question in spec or sele
TRANS
real(12)
Local transformation matrix
TRAYH
real
Tray height
TRAYOW
real
Tray other width
TRAYRW
real
Tray Reduce Width
TRAYSW
real
Tray side width
TRAYW
real
Tray Width
TRCG
logical
DRAFT user defined symbol trace flag
TRCLIN
word
Trace line
TRCOS
element
Symbolic trace other side style reference
TRCTS
element
Symbolic trace this side style reference
TREADD
real
Tread Depth
TREADO
real
Tread Overlap
TREATP
element
Tread type
TREF
element
Tail reference
TRGENA
logical
Initial Value
TRIMCE
integer(10000)
Array of Trimmed Cells
TRIMTY
word
CTWALL TRIM TYPE
TRLEN
real
Tracing length
TRSF
element
Tag ruleset reference
TRUN
real
Truncation value (+ve) or percentage (-ve)
TRUNTX
string(80)
Truncation value (+ve) or percentage (-ve) text
TSFBR
logical
Spooling marker for leave tube
TSIZ
real
Terminator size
TSIZTX
string(80)
Terminator size text
TSKDEF
element
Reference to the task definition
TSKFCE
element
Reference to the flow chart element
TSKNAM
string(80)
Task Definiton Name
TSKREF
element(500)
Assigned tasks list
TSLEN
real
Total suspension length
TSPE
element
Tracing spec reference
TSPR
element
Trace specification component reference
TTEX
string(2000)
T Text string
TTFACE
string(128)
TrueType font face name
TTFDES
string(128)
TrueType font description
TTFENA
logical
TrueType fonts enabled flag
TTFIND
integer
TrueType font index
TTHOFF
real
Top Tube Hoop Offset
TTYP
word
Template type
TUCL
real
Tube centreline length of branch
TUFG
logical
Tubing flag
TUFL
logical
Tube flag
TULE
real
Tube length of branch
TUNI
string(20)
Default unit of value (falls back to dimension default if not set)
TVALS
real(1000)
t Values
TVIS
logical
Top visibility flag
TVOL
real
Terrain volume
TWALLT
real
Tail wall thickness
TWIDIS
real(2147483647)
Profile twist distance
TWIDTH
real
Tread Width
TWIST
logical
True if twisted
TWIVEC
real(2147483647)
Profile twist orientation vector
TWLEN
real
Total weld length
TWRF
element
Tail Working Point (Router)
TWSHRH
string(32)
Detailing Bolt Set Head-Side Tapered Washer
TWSHRN
string(32)
Detailing Bolt Set Nut-Side Tapered Washer
TWSTAN
real
Twist angle
TXALIGN
string
Text alignment
TXAREA
real
Total Cableway X-area
TXCOLG
integer
GLabel style text colour
TXCOLO
integer
Text colour
TXCONU
integer
Text colour number
TXDIR
integer
Text direction pline number
TXGRGB
integer(4)
RGB glabel style text colour
TXGRGP
integer(4)
RGB glabel style text colour physical
TXHINT
word
Text height interpretation mode flag
TXSPLI
logical
Text splitting flag
TXSTRF
element
Text style reference
TXSTRI
string(1000)
Text String for enhanced LineStyles
TXTFNT
integer
Labelling text font
TXTRGB
integer(4)
RGB text colour
TXTRGP
integer(4)
RGB text colour physical
TXTTYP
integer
Labelled text type
TXTVAL
string(80)
Detailing Element Text Value
TYNU
integer
Number type
TYPE
word
Type of the element, ignoring UDET, truncated to 4 or 6 characters
TYPEA
string(10)
TYPEA
TYPEB
string(10)
TYPEB
TYPECD
integer
Type code
TYPECE
integer
Type code
TYPEDB
string(6)
DB type
TYPEXPRESSION
string(1000)
Type Expression
TYPEXTYPE
string(15)
Type expression type
TYPINC
logical
Type is inclusive
TYPREFERENCE
element
Reference to a datatype element for an RDF Statement Object
TYSEQU
integer
Type Sequence Number
TZAXI
dir
tail Z axis
