Data Model
Introduction to Attributes
List of All Attributes
: Attribute N
Attribute N
Attribute Name
Data Type
Qualifier
Description
N
real
Position northing
NACCNT
integer
Non-additive changes count
NAMATT
string(200)
Naming attribute
NAME
string(500)
Name of the element
NAMEDB
string
DB name
NAMESQ
string(700)
Type. sequence number and name of element
NAMETY
string(700)
Type and name of the element
NAMN
string(500)
Name of the element (without leading slash)
NAMTOL
logical
True if name is too long
NAMTYP
string(700)
Type and full name of element
NANGLE
real
North angle
NANPT
integer
Anopoint number
NARE
element
Reference to neutral axis
NBEVIT
real(2)
Pathtime except starts, I-bevel
NBEVXT
real(2)
Pathtime except starts, X-bevel
NBEVYT
real(2)
Pathtime except starts, Y-bevel
NBLS
integer
Number of blastings
NBORE
real
Allowable Nominal Bore
NBRNS
integer
Number of burning starts
NCDATE
datetime(2)
NC tape date
NCHAR
integer
Number of label characters
NCHOLE
integer
Number of cut holes
NCOF
pos
Nett centre of gravity
NCOL
integer
Number of columns
NCONNE
integer
Mismatched connections. i.e. no valid backpointer
NCORSZ
real
Size of the neutral core
NCREAT
string(256)
Creator of the nest
NCTGAP
real
End cut gap or overlap
NCTTYP
integer
Type of end cut (Undefined, Sniped, Tight)
NCUTNT
integer
Number of cutouts and notches
NCUTOU
integer
Number of cutouts
NCUTS
integer
Number of cuts in a mitred bend
NDDRHO
integer
Number of different diameters of drilled holes
NDFLT
real
Numeric default value for a UDA
NDHOLE
integer
Number of drilled holes
NDTINT
integer(2)
NC tape date
NDTTXT
string(22)
NC tape date text
NENDCT
integer
NGMR
element
Negative geometry set reference
NGSD
integer
Number of GSDs
NHOLE
integer
Number of holes
NIDLAB
real
Pathtime except idle time for label
NIDLT
real(2)
NLABEL
integer
Number of labels
NLBL
integer
Number of labels
NLCOLO
integer
Note colour
NLCONU
integer
Note colour number
NLOA
real
Nominal load
NLOFF
real
Nosing Line Offset
NLPN
integer
Note/framing pen
NLSTREF
element
Note linestyle Reference
NLSTRT
integer
Number of label starts
NLSTYL
integer
Note linestyle
NMARK
integer
Number of markings
NMBLS
integer
Number of markblastings
NMKHOL
integer
Number of marked holes
NMOF
real(9)
Nett moments of inertia
NNOTCH
integer
Number of notches
NOCLIP
logical
View no clipping flag
NOCOL
integer
Number of pin jig columns
NOCOPY
logical
Detailing Feature Copy Flag
NODIMS
logical
No Dims Flag
NODREF
element
Revision Number Definition
NOECOR
integer
Number of earth cores
NOEXTCREATION
logical
Location extract create suppression flag
NOFF
integer
Number off
NOFG
logical
Link constraint inversion flag
NOGRPS
integer
Number of groups
NOHLRF
logical
NoHLRFlag
NOISEC
string(26)
Noise category
NOLNKP
logical
Linked Documents distribution disabled
NOMARK
logical
True if unmarked
NOMBIN
real(200)
word
List of valid Nominal bores in Inches
NOMBMM
real(200)
word
List of valid Nominal bores in MM
NOMDIA
real
Nominal Bolt Shank Diameter
NOMDIR
dir
Nominal slope direction
NOMLEN
real
Nominal Bolt Shank Length
NOMREF
element
Nominal bore table reference
NOMXRF
element(500)
Return reference from NOMTAB element to SPECs
NONCOR
integer
Number of neutral cores
NOPGS
integer
Number of openings
NOPKND
integer
Number Part Type: 1=alpha,2=number,3=custom
NORM
dir
Plane normal
NOROW
integer
Number of pin jig rows
NORTHING
pos
Northing part expressed as a position
NOSOFF
real
Nosing Offset
NOTF
element
Cross-reference to NOTE/VNOT/SYTM
NOTIFY
element(20)
Notification states
NOTREAD
integer
Number of treads
NPDESC
element(5000)
List of non primary offspring
NPILL
integer
Number of jig pillars
NPLAOR
real(2)
Nested part origin
NPLDFA
string(80)
Nesting default file 1
NPLDFB
string(80)
Nesting default file 2
NPLIST
element(500)
All NATPs attached to route node
NPLMIR
integer
Quantity mirrored nested plates
NPLNOR
integer
Quantity normal nested plates
NPLTOT
integer
Total quantity nested plates
NPOS
pos
Position in owner
NPOSE
real
Easting of position wrt owner
NPOSN
real
Northing of position wrt owner
NPOST
integer
Number of Posts
NPOSU
real
Upping of position wrt owner
NPPT
integer
Ppoint number
NPRLEN
real
Nested profile length
NPRSID
string(26)
Side of nested profile
NPRSTP
real(2)
Nested profile starting position
NPRVEC
real(2)
Local rotation vector of part
NPSIDE
string(80)
Side of nested part
NPXYP
real(2)
Position of part(x,y)
NREL
integer
Nodal releases
NRGRPS
integer
Number of groups
NROW
integer
Number of rows
NRPARM
integer
Number of rest plate parameters
NRULEE
integer
Number of rule inconsistencies on element
NSESS
integer
Number of extant sessions
NSIHOL
integer
Number of sink holes
NSIZ
real
Nominal size
NSLHOL
integer
Number of slot holes
NSPE
element
Specification for NOZZLE
NSRF
real
Nett surface area
NSSLHO
integer
Number of different sizes of slot holes
NSTART
integer(2)
Number of non-burning starts
NSTD
element
Non-standard bolt length (reference to DTAB)
NSTFAC
real
Number of starts - factor
NSTRT
integer(3)
NSTRTI
integer(2)
Number of burning starts I-bevel
NSTRTX
integer(2)
Number of burning starts X-bevel
NSTRTY
integer(2)
Number of burning starts Y-bevel
NSTTYP
integer
Nesting Type
NTEXT
string(13)
Null text
NTHOLE
integer
Number of threaded holes
NTRLEN
real
Neutral length
NUCDNA
real
Distance to nearest anchor
NUCDNE
real
Distance to the Nearest Edge
NUCDNR
element(2)
Nearest Adjacent Anchor
NULLRE
logical
attr
T/F on attributes that are null value references
NULVAL
string(40)
String to be used if the attribute is blank
NUMB
integer
Number
NUMBDB
integer
DB number
NUMCOR
integer
Number of cores in a cable
NUMD
real
Generic Number Data Storage
NUMOFF
integer
Number of Sheets in Drawing
NUSED
integer
Number of used raw plates
NVIEWF
string(73)
integer
Neutral viewer filename
NVOL
real
Nett volume
NWEI
real
Nett weight
NWELDS
integer
Number of attached welds on a piping component
NXTDBN
integer
Next DB number
NXTDBU
integer
Next Unique DB number
NXTEXN
integer
Next DB extract number
NXTFDB
integer
Next DB file and DB number
NXTFLN
integer
Next DB file number
NXTHB
element
Reference to next (future) hub
NXTKEY
integer
next UDA/UDET key
NXTLOCATIONS
element(200)
List of online neighbour LOCs for a LOC
