Data Model
Introduction to Attributes
List of All Attributes
: Attribute D
Attribute D
Attribute Name
Data Type
Qualifier
Description
D
real
Position downing
DACC
string
Database access
DACCLA
logical
True if DAC allows element to be claimed
DACCOH
logical
True if DAC allows element hierarchy to be copied to another DB
DACCOP
logical
True if DAC allows element to be copied to another DB
DACCRE
logical
elemtype
True if DAC allows element to be created
DACDEL
logical
True if DAC allows element to be deleted
DACDRO
logical
True if DAC allows element to be dropped
DACERR
string(120)
attr
Returns the DAC error
DACEXH
logical
True if DAC allows element hierarchy to be exported
DACEXP
logical
True if DAC allows element to be exported
DACISS
logical
True if DAC allows element to be issued
DACMOD
logical
attr
True if DAC allows attribute of element to be modified
DACOUH
logical
True if DAC allows element hierarchy to be output
DACOUT
logical
True if DAC allows element to be output
DAENABLED
string(10)
Enable Autolabels for view (as text)
DAENI
integer
Enable Design Element Auto Labelling for view (Off, On)
DAEXLL
logical
Dimension auto external line length
DAREF
element
Reference of associated dataset area
DARREF
element
Design area reference
DARSF
element
Design Element Auto Labelling rule set reference
DASSCI
element(500)
Reference Array of all direct associates with constraints
DASSOS
element(500)
Reference Array of all associations with constraints
DATASO
element(10)
DBView or DBViewSet reference array for Datasheet Template
DATE
string(12)
Date
DATEFO
string
Date format
DATIM
string(19)
LMI Date/time
DATINT
integer(2)
Date
DATONE
integer
Date 1
DATTWO
integer
Date 2
DATTXT
string(22)
Date
DBAC
string
DB Access, MULTIWRITE or UPDATE
DBALL
element(8000)
List of DBs allocated to location
DBATTRIBUTE
word
Database attribute
DBBLOB
blob(2147483647)
Database Binary Large Object
DBCL
string
DB Claim
DBCNTL
logical
True if element is in a control DB
DBCRITERIA
integer(2000)
Crteria(expression) for DBs in the DBset
DBELET
word
Element type
DBEXNO
integer
DB Extract Number
DBF
element
Database reference attribute
DBFI
string
DB filename
DBFN
integer
DB file number
DBHASPRODUCT
logical
Has a product been associated with this DB?
DBLC
element(1000)
List of LOCs belonging to a DB
DBLNKP
logical
Linked Documents (DB) distribution flag
DBLS
element(5000)
List of DBs belonging to MDB
DBLSFULL
element(5000)
List of DBs belonging to MDB, expanding DBsets
DBNA
string
DB name
DBNU
integer
DB Number
DBOT
real
Bottom diameter
DBPR
element(8000)
List of DBs Primary at location
DBPRODUCTAVAILABLE
!UNKNOWN(50)
word
Products available for databases
DBPRODUCTTEXT
string(1024)
Product associated with this DB
DBPRODUCTWRITE
logical
word
Flag determining whether product can write to DB
DBRBEG
integer
DB range start
DBREF
element
DB reference
DBREND
integer
DB range end
DBSESS
integer
Last DB session
DBSETLS
element(5000)
List of DbSets in MDB
DBSHIE
element(5000)
Database hierarchy within a DBSET
DBSLEV
element(5000)
Databases at a level within a DBSET
DBSLIS
element(5000)
Databases within a DBSET
DBSORD
string(120)
Order dbs in dynamic DBSET by name, type or number
DBSSTP
element(8000)
DBs in a stamp
DBSTF
element
Database set reference attribute
DBTE
string
DB Text Encoding
DBTY
word
DB type (DESI, CATA etc)
DBUsers
element(10000)
Current Users in the system using this DB
DBUSRX
element(10000)
Current Users in the system using this DB or any extract descendants
DBVAR
logical
True if element is in a variant DB
DBVWSTREF
element(50)
Database View Set reference array
DBWRITE
logical
True if element is in a writable DB
DCLA
string
Database claim mode
DCLNCO
string(120)
Default Ceiling Code
DCLNHE
real
Default Ceiling Height
DCLNTY
string(120)
Default Ceiling Type
DCMPID
integer
Definition component identity
DCODE
string
Direction code
DCON
word
Design PPoint connection type
DCONFINT
integer
Draw Connector Flags Integer
DCONFLAGS
string(120)
DCORRO
real
Derived corrosion
DCRFA
element(10)
Array of Design datasets for Design Code/Criteria
DCSTYF
element
Design change style reference
DCTILT
real
Default Ceiling Tile Thickness
DDDF
string(1000)
Default Design data value
DDEF
real(3)
Port distance flexibility defaults
DDEG
real
Dimension line angle
DDEGTX
string(80)
Radial dimension angle text
DDEP
integer
Database depth within hierarchy (World is 0)
DDESP
real(100)
Design parameters as distance
DDIR
dir
Design PPoint spherical direction
DDNM
element
Design element reference
DDNMX
real
DDNM X position
DDNMXY
real(2)
DDNM XY position
DDNMY
real
DDNM Y position
DDNX
string(120)
Design element as text
DDOORS
real
Default Door Sill
DDPR
string(1000)
Design data property value
DDRFA
element(10)
Array of default design datasets (for template)
DEALAL
logical
True if location locked due to deallocation of dbs
DEALDB
element(300)
Reference array for locations where DB id being deallocated
DECGAP
real
Decoration Gap
DECMOD
integer
Decoration Mode
DECOFF
real(2)
Decoration offset
DECP
integer
Decimal places
DECPRC
integer
Decimal precision
DECREP
real
Decoration Repeat
DECSEP
string
Decimal separator
DECSIZ
real
Decoration Size
DEFA
real
Default
DEFATT
word(2000)
Default List of all attributes for element
DEFAULTATT
word
Attribute on default location to use for default
DEFAULTEXP
integer(2000)
Expression used to calculate default
DEFAULTLOCATION
word
Attribute to follow to get default location
DEFERD
element(10000)
Deferred DBs in MDB
DEFHOM
element
Default allocation home
DEFLEN
real
Fixed length of the weld
DEFLNK
element
Link to terrain definition
DEFREF
element
Reference to a definition element.
DEFSLO
real
Default pipe slope
DEFSPK
element
Default Reference of SPEC for branch members
DELANG
real
Angle applied to repeat elements
DELDAT
datetime(2)
Delivery Date
DELDSG
word
Delivery Designation flag
DELP
pos
D-position in structure
DELPE
real
Easting of D-Position in STRUC
DELPN
real
Northing of D-position in STRUC
DELPU
real
Upping of D-position in STRUC
DELTAE
real
Easterly Offset applied to repeat elements
DELTAN
real
Northerly Offset applied to repeat elements
DELTAU
real
Vertical Offset applied to repeat elements
DEMIX
integer
Index of Demote Status Value
DEMRDY
logical
Flag to signify the completion of demolition definition
DEMVOL
element(20)
References to Volumes to be demolished referenced laser survey
DENS
real
Spot value of density
DEPATT
word(2000)
Attributes that a rule or catalogue parameterised expression is dependent upon
DEPD
string(250)
word
Default value of local design property
DEPL
word(100)
List of local design properties
DEPR
string(250)
word
Local design property value
DEPREF
element(500)
List of elements connected to branch tail
DEPTH
real
Depth
DESC
string(120)
Description of the element
DESCAL
string(256)
Descaling
DESELE
element
Reference to Design Object
DESELM
element(50)
References to Design Elements
DESGEO
element(5000)
Design geometrical dependencies
DESLNK
element(20)
Connectivity Design Model Link
DESMOD
integer
Design Mode
DESP
real(100)
Design parameters
DESREF
element(10)
Design reference
DESSTR
element
Design Structure Reference
DEST
string(26)
Destination
DESXCL
logical
Design Outfitting excluded Geometry
DETA
logical
Detail flag
DETR
element
Detailing text reference
DEXREF
element
External element reference
DFBRADIUS
real
element
Default bend radius
DFFL
real(6)
Displacement force flexibility
DFHOME
element
element, elemtype
Get default home element
DFLA
string
Radial dimension type flag
DFLF
real(3)
Translational spring values
DFLRCO
string(120)
Default Floor Code
DFLRHE
real
Default Floor Height
DFLRTY
string(120)
Default Floor Type
DFLT
string(500)
Default value for the attribute
DFLTA
string(1000)
Defaults for Type 1 annotation - special attribute for use by ADP
DFLTB
string(1000)
Defaults for Type 2 annotation - special attribute for use by ADP
DFLTC
string(1000)
Defaults for Type 3 annotation - special attribute for use by ADP
DFLTD
string(1000)
Defaults for Type 4 annotation - special attribute for use by ADP
DFNM
string(120)
Document filename
DFON
integer
Dimension text font
DFONTN
string(80)
Dimension text font name
DFUN
element
Default unit
DGABMA
real
Helper Line Distance Start
DGABME
real
Helper Line Distance End
DGABPA
real
Detailing Dimensioning Start Distance
DGABPE
real
Detailing Dimensioning End Distance
DGABRE
integer
Detailing Graphic Measure Line Absolute relativ flag
DGACCU
integer
Detailing Graphic Units Accuracy
DGADDM
logical
Detailing Graphic Additional Measure
DGADDT
logical(3)
Detailing Graphic Additional Measure Type Options
DGALPO
string(32)
Deatiling Graphics Arc Length Postfix
DGALPR
string(32)
Deatiling Graphics Arc Length Prefix
DGALTI
string(32)
Deatiling Graphics Arc Length Title
DGANCH
integer
Detailing Graphic Anchor Point Option
DGANPT
real(2)
Detailing Graphic Anchor Point Dx / Dy
DGARLT
integer
Detailing Graphic Arc Length Dimension type
DGBAST
real
Triangle Base Line
DGBOLD
logical
Detailing Graphic Text Attribute Bold
DGCENT
logical
Detailing Graphic Flag Text centred
DGCPOP
integer
Detailing Graphics Arc Length Center Point Option
DGCRAD
real
Detailing Graphic Circle Radius
DGCRST
integer
Detailing Graphic Polyline Attribute Creation sub type
DGCRTY
integer
Detailing Graphic Attribute Creation Type
DGDARK
integer
Detailing Graphic Display Criteria
DGDBEA
real
Detailing Graphic Polyline Attribute Drawback end angle
DGDBED
real
Drawback End Diameter
DGDBEL
real
Detailing Graphic Polyline Attribute Drawback end length
DGDBET
integer
Detailing Graphic Symbol Attribute Drawback end type
DGDBGN
integer
Detailing Graphic Group number
DGDBSA
real
Detailing Graphic Polyline Attribute Drawback start angle
DGDBSD
real
Drawback Start Diameter
DGDBSL
real
Detailing Graphic Polyline Attribute Drawback start length
DGDBST
integer
Detailing Graphic Symbol Attribute Drawback start type
DGDISL
real
Detailing Graphic Distance to Dimension Line (longitudinal)
DGDIST
real
DGDLOL
real
Detailing Graphic Distance Line Overlength
DGDLPO
integer
Detailing Graphic Radius Dimension Position on Dimension Line
DGDLTR
element
Reference to DGDLT Element
DGDLTX
real
Detailing Graphic Polyline Attribute Delta X
DGDLTY
real
Detailing Graphic Polyline Attribute Delta Y
DGDOLF
real
Detailing Graphic Dimension Line Overlength (Front)
DGDOLR
real
Detailing Graphic Dimension Line Overlength (Rear)
DGDTDP
real
Detailing Graphic Elevation Attribute Distance to dimension point
DGDTES
real
Detailing Graphic Elevation Attribute Distance to elevation symbol
DGEBPA
logical
Detailing Graphic Flag Parallel Planes Only
DGELVT
real
Elevation Value
DGEXB
real
Detailing Graphic Distance to extension line begin
DGEXE
real
Detailing Graphic Distance to extension line end
DGEXET
integer
Detailing Graphic Polyline Attribute Type of execution
DGFANG
integer
Fill Angle Index
DGFCOL
integer
Detailing Graphic Fill Color
DGFDIS
integer
Fill Distance Index
DGFILL
integer
Detailing Graphic Fill flag
DGFLTV
integer
Detailing Graphic Line Pattern Number
DGFONT
integer
Detailing Graphic Font Number
DGFORM
integer
Detailing Graphic Value Format
DGFPAD
real
Pattern Repeat Factor
DGFPAN
real
Fill Pattern Angle
DGFPFA
real
Fill Pattern Factor
DGFPTY
integer
Pattern Type
DGFRME
integer
Detailing Graphic Text frame
DGFSHA
real
Detailing Graphic Shading Opacity
DGGAD
real
Detailing Graphic global angle direction
DGGONP
string(32)
Deatiling Graphics Gon Postfix
DGHASL
logical
Detailing Graphic Elevation Attribute Has second line
DGHGTH
integer
Detailing Graphic Text Height
DGHLDI
real
Detailing Graphic Distance to Help Line
DGHLLE
real
Detailing Graphic Symbol Attribute Helpline Length
DGHLLO
integer
Detailing Graphic Help Line Length Option
DGHLLV
real
DGHLOL
real
Detailing Graphic Help Line Overlength
DGHLPO
integer
Detailing Graphic Radius Dimension Position on Help Line
DGHWR
integer
Detailing Graphic Text Height-to-Width ratio
DGISCL
logical
Detailing Graphic Symbol Attribute Is Closed
DGISEA
integer
Automatic Placement
DGITAL
logical
Detailing Graphic Text Attribute Italics
DGJOIN
element
Detailing parent element reference
DGJOIS
element
Detailing child element reference
DGLAYN
integer
Detailing Graphic Layer Number
DGLCLO
integer
Close Polyline
DGLDAN
real
Detailing Graphic Leader Angle
DGLDFA
real
Detailing Graphic Elevation Attribute Factor for line distance
DGLDLE
real
Detailing Graphic Leader Length
DGLDOP
integer
Detailing Graphics Leader Line Option
DGLDTY
integer
Detailing Graphic Leader Type
DGLEN
real
Detailing Graphic Polyline Attribute Length
DGLFIL
integer
Fill Polyline
DGLLEN
integer(3)
Text Line Lengths
DGLLIN
integer
Detailing Graphic Multi-line Text Length
DGLLTY
integer
Detailing Graphic Elevation Attribute Type of leader line values
DGLPFL
real
Detailing Graphic Line pitch first line
DGLPIA
real
Detailing Graphic Line pitch absolute
DGLSPA
real
Line Spacing
DGLTA
real
Detailing Graphic Line termination angle
DGLTIV
integer
Detailing Graphic Line Type invisible
DGLTL
real
Detailing Graphic Line termination length
DGLTR
element
Reference to DGLTYP Element
DGLTSB
integer
Detailing Graphic Line termination begin
DGLTSE
integer
Detailing Graphic Line termination end
DGLTVI
integer
Detailing Graphic Visible Line Type number
DGLVSD
integer
Level Symbol Docking
DGLVST
integer
Level Symbol Type
DGMALI
logical
Detailing Graphic mark line flag
DGMATT
integer
Detailing Graphic Measure Line Text type
DGMBAS
real(2)
Detailing Dimensioning Base Point
DGMBEG
real(2)
Detailing Dimensioning Origin
DGMDIS
real
Detailing Graphic Distance to Dimension Point
DGMFMT
integer
Detailing Graphic Value Formatting Option
DGMKDX
real
Delta X
DGMKDY
real
Delta Y
DGMLAT
integer
Detailing Graphic Angle Measure Line type
DGMLEG
real(2)
Detailing Dimensioning Leg End Point
DGMLL
real
Detailing Graphic Marker Line Length
DGMODE
integer
Detailing Graphic Polyline Attribute Mode
DGMORA
real(2)
Detailing Dimensioning Start Orientation
DGMORB
real(2)
Detailing Dimensioning End Orientation
DGMPTD
real
Detailing Graphic Minimum Point Distance
DGMTRL
real
Detailing Graphic Triangle Measure Line length
DGMTRT
integer
Detailing Graphic Triangle Measure Line type
DGMTXT
string(80)
Deatiling Graphics Measure Option Text
DGMTYP
integer
Detailing Graphic Angle Measure Type
DGNINV
integer
Detailing Graphic Number of invisible characters
DGNLIN
integer
Number of Lines
DGNOSI
integer
Detailing Graphic Symbol Attribute Number of sides
DGOLIN
integer
Number of Lines above Marker
DGONEC
string(100)
Detailing Graphic Symbol Attribute Text 1 Content
DGONES
logical
Detailing Graphic Symbol Attribute Text 1 selected
DGORAN
real
Orientation Angle
DGORIE
integer
Detailing Graphic Text Orientation
DGORTY
integer
Detailing Graphic Radius Dimension Orientation Type
DGPAAN
real
Pattern Angle
DGPACK
integer
Detailing Graphic Packed Word
DGPATT
integer
Detailing Graphic Line Pattern repeat factor
DGPDDR
element(100)
Reference to DGPDD Element
DGPEN
integer
Detailing Graphic Dimension Pen
DGPICK
integer
Detailing Graphic Pick Element
DGPIV
integer
Detailing Graphic Pen invisible
DGPTYP
integer
Detailing Graphic Polyline Attribute Polyline Type
DGPVI
integer
Detailing Graphic Pen visible
DGPXY
real(200)
Detailing Graphic 2D Points
DGPXYZ
real(300)
Detailing Graphic 3D Points
DGRADI
real(32)
List of radius
DGRDP
integer
Detailing Graphic Radius dimension position
DGRDT
integer
Detailing Graphic Radius dimension type
DGREPR
integer
Detailing Graphic Symbol Attribute Representation Rule
DGSCAL
real
Scaling Factor
DGSEGT
integer
Detailing Graphic Segment Type
DGSHAD
integer
Shading
DGSIDI
real
Detailing Graphic Polyline Attribute Side displacement
DGSLBA
real
Detailing Graphic Slope Base Value
DGSLCO
string(32)
Detailing Graphic Elevation Attribute Content of second line
DGSMH
real
Detailing Graphic Sm_Sysm height
DGSMW
real
Detailing Graphic Sm_Sysm width
DGTALI
integer
Detailing Graphic text alignment
DGTANG
real
Detailing Graphic text angle
DGTAR
element
Reference to DGTXAT Element
DGTARC
integer
Detailing Graphic Arc Attribute Type of arc
DGTATB
integer
DGTCOL
integer
Detailing Graphic Text Color
DGTPLP
integer
Text Position on Level Point
DGTPOS
integer
Detailing Graphic Text position
DGTRDY
real
Detailing Graphic Slope Triangle DY
DGTTOM
integer
Detailing Graphic text position related to mark out point
DGTWOC
string(100)
Production Phase
DGTWOS
logical
Detailing Graphic Symbol Attribute Text 2 selected
DGTXAD
integer
Detailing Graphic Symbol Attribute Text Adjustment
DGTXAN
integer
Detailing Graphic Text Anchor
DGTXB
real
Detailing Graphic Distance to text begin
DGTXE
real
Detailing Graphic Distance to text end
DGTXLI
integer
Detailing Graphic Flag for the lift of the last decimal number
DGTXRF
element(100)
Reference to DTTXTS Element
DGTXST
integer
Detailing Graphic Text Attribute style
DGTXT
string(80)
Display Text
DGTXTL
!UNKNOWN(20)
Detailing Graphics Text
DGTYPE
integer
Detailing Graphic Type
DGUNIT
integer
Detailing Graphics Units system
DGUSOF
real
Detailing Graphic underscore offset
DGVIEW
integer
Detailing Graphic View Number
DGWASI
real
Wave Size
DGWCIR
integer
Girth Weld Flag
DGWFLG
integer
Shop Weld Flag
DGWFRM
logical
Detailing Graphic Symbol Attribute Draw with frame
DGWNTX
integer
Number of Weld Spec Texts
DGWNUM
integer
Number of Waves
DGWSCA
real
Z3 Window Scale
DGWSLS
integer
Detailing Graphic Welding Symbol Left side flag
DGWSOS
integer
Detailing Graphic Welding Symbol Other side flag
DGWSSN
integer
Detailing Graphic Welding Symbol Number
DGZART
integer
Detailing Graphic Drawing Type
DHTEST
integer(500)
Test locator expression
DHTEXT
integer(500)
Default home identifier expression
DIAGXPOS
real
X position of the symbol on Visio drawing in mm
DIAGYPOS
real
Y position of the symbol on Visio drawing in mm
DIAM
real
Diameter
DIAREF
element(500)
Diagram reference array for schematic elements
DICMID
integer(100)
Predefined instance component identities
DIME
logical
DRAFT user defined symbol dimension flag
DIMPAT
string(1024)
Imported attribute
DIMPOS
pos
Derived 3D dimension position
DIMTXT
string(40)
Dimensions text
DINTER
string(257)
Default Interference class
DINTHK
real
Default insulation thickness
DIR
dir
Direction
DIRATT
string(120)
Name of attribute (or pseudo) to be used to set direction for automatic label placement
DIRCOD
integer
Direction Coding
DIREV
dir
Direction evaluation
DIRMOI
integer
Auto labelling direction setting (Horizontal, Vertical, Pline, Attribute)
DIRX
real(3)
grid limit in x direction
DIRXP
integer(500)
Direction expression
DIRY
real(3)
DISCIF
element
Reference of DISCIPLINE Element
DISCIS
element(50)
Associated disciplines
DISP
real(3)
Translation displacements
DISPNM
string(120)
Display Name
DISPNN
string(120)
Display Name
DIST
real(2)
Distances
DISTAG
string(50)
Display tag
DISTFH
real
integer
Distance from head
DISTFN
real
Distance from next point
DISTFP
real
Distance from previous point
DISTM
real(2)
Distances to M1 and M2 curves
DKEY
word
Data Key
DLCNMINT
integer
Dimension line continuous mode (Default, ByVStyle, Off, On)
DLCNTMODE
string(20)
Dimension line continuous mode (as text)
DLCOLO
integer
Dimension line colour
DLCONU
integer
Dimension line colour number
DLEV
integer
Drawing level
DLFG
string
Linear/Angular dimension line flag
DLIM
real(6)
Displacement limit
DLIST
word(2000)
List of all possible dist att types
DLNRGB
integer(4)
RGB dimension line colour
DLNRGP
integer(4)
RGB dimension line colour physical
DLPN
integer
Dimension line pen
DLSTREF
element
Dimension linestyle Reference
DLSTYL
integer
Dimension linestyle
DMFA
element(2)
ISODRAFT Reference Dimension attribute
DMFL
real(9)
Displacement moment flexibility
DMSP
real
Lower limit to spacing between parallel dimensions
DMSPTX
string(80)
Dimension spacing text
DMSTRF
element
Dimension style reference
DMTX
string(1000)
Dimension text
DMTY
word(2)
DNAME
string(50)
Display Name
DNOTCP
element
Draw Note Current Command Line Point
DNST
real
Density
DOCCHG
element(2147483647)
Reference to changed related documents
DOCNUM
string(40)
Document Number
DOCREF
element
Document reference
DOCXRF
element(500)
Return reference from Design element to DOCITM element
DOFF
real
Dimension line offset
DOFIL
string(73)
Drawing Object filename
DOUHOL
logical
Doubling hole
DOUPGR
logical
True if element is recommended to be upgraded in current db
DPBO
real
integer
Design point bore
DPCO
word
integer
Design point connection type
DPCOU
integer
Number of valid design points
DPDI
dir
integer
Design point direction
DPDIST
real
Draw proportional distance
DPFN
string(1024)
ISODRAFT dynamic detail plotfile name
DPGR
real
integer
Design Point Gradient
DPGRID
integer
ISODRAFT dynamic detail grid reference attribute
DPKEY
word
Draft derived Pline identifier key
DPLS
integer(200)
List of valid design points
DPNAME
string(120)
Display Name
DPOFF
real
Dimension point offset
DPOINX
string(480)
Design point information
DPOS
pos
Dimension line/arc position
DPPS
pos
integer
Design point position
DPREMA
real
Design pres. max
DPREMI
real
Design pres. min
DPRO
string(1000)
Parameterised Property Expression (Default)
DPSF
element
Design PPointset reference
DPVI
integer(200)
List of visible design points
DRAD
string(1000)
Radial offset
DRAFTM
string(256)
Draftsman
DRAWNO
string(26)
Drawing number
DREVAY
element(50)
DRWG revisions array
DRFILE
string(73)
Drawing File Name
DRFLOINT
integer
Draw Flow (ByVStyle, None, Forward, Back)
DRFLOW
string(20)
Draw Flow (as text)
DRFNUM
integer(20)
Drawing File Numbers
DRFTYP
integer(20)
Drawing File Types
DRGP
integer
Drawing priority (used to determine how to draw SCTN)
DRMXTL
integer
Draft general max text length
DRNE
dir
Plane normal at end of SCTN/GENSEC
DRNS
dir
Plane normal at start of SCTN/GENSEC
DRPS
pos
Derived position for steelwork
DRRF
element
Old spooler drawing reference
DRSSRE
element
Draft Symbol set reference
DRSTYP
string(120)
Drawing subtype
DRSTYTABLE
string(120)
Drawing subtype table
DRTITL
string(1000)
Drawing title
DRTMPR
element
Draft template reference
DRTYPE
string(120)
Drawing type
DRTYPTABLE
string(120)
Drawing type Table
DRUMLN
real
Drum length
DRWGN
string(1000)
Drawing number
DSCO
string(120)
Design code
DSESS
string(640)
integer
Date of specified session
DSET
logical(3)
Displacement limits set flag - ignore values if FALSE
DSGNTN
string
Designation
DSHANG
real
Draft absolute sheet angle
DSHPOS
pos
Draft sheet position derived from 3d
DSIAST
element(500)
Datasheet Instance assigned tags reference array for Datasheet Instance
DSIFIL
string(2000)
Datasheet Instance filename
DSNO
integer
Datasheet number
DSSUBT
string(2000)
Datasheet sub title
DSTAPN
string(120)
Datasheet Additional Page Name
DSTAPT
string(120)
Datasheet Additional Page Type
DSTITL
string(2000)
Datasheet title
DSTNCE
real
Distance
DSTREF
element
Datasheet Template reference for Datasheet Instance
DSTY
string
Radial dimension style flag
DSTYPE
integer
Datasheet type
DSUPCA
logical
Drawing Engine suppress caching
DTADDR
element
Detailing Job Address
DTADDT
string(80)
Additional Text Data
DTADEG
real
Dimension Text Angle Degrees
DTADGP
real
DTADHO
integer
Bolting: Additional hole type
DTADPU
integer
Bolting Centre Punch Type
DTAN
string
Dimension text angle flag
DTANFL
real
Detailing Fabrication Item / Angle of cut - Flange/Left
DTANFR
real
Detailing Fabrication Item / Angle of cut - Flange/Right
DTANGZ
real
Angle to Zero Line
DTANSA
string
Dimension text angle flag style angular DTANSA
DTANSL
string
Dimension text angle flag style linear DTANSL
DTANSR
string
Dimension text angle flag style radiant DTANSR
DTANWL
real
Detailing Fabrication Item / Angle of cut - Web/Left
DTANWR
real
Detailing Fabrication Item / Angle of cut - Web/Right
DTAOBV
integer
Number of bolting vectors
DTAREA
real
Area
DTAUTW
integer
Clamping Length Balancing Mode
DTBCKD
datetime(2)
Detailing Job Backup Date
DTBCOA
string(80)
Detailing Base Coating
DTBDIA
real
Detailing Element Border Diameter
DTBDR
element
Reference to a bolt definition element
DTBNAM
string(32)
Detailing Model Bolt Name
DTBNDB
string(32)
Detailing Model Bolt Name for Database
DTBNDR
string(32)
Detailing Model Bolt Name for Drawings
DTBREV
element
Reference to Revision
DTBSET
integer(10)
Bolt Set Composition
DTBSR
element
Reference to a bolt set definition element
DTCATR
string(10)
Bolt Set Component Catalogue Numbers
DTCDAT
datetime(2)
Detailing Drawing Creation Date
DTCH
real
Dimension text character height
DTCHTX
string(80)
Dim text char height text
DTCITY
string(80)
Detailing Address City
DTCKEY
integer
Bocad Detailing Comment Key
DTCLAS
integer
Bocad Detailing Element Class
DTCLHO
real
Bolt Hole Clearance
DTCLIP
integer
Clamping Length Calculation Mode
DTCLMA
real
Bolt Clamping Length (maximum)
DTCLMI
real
Bolt Clamping Length (minimum)
DTCLML
real
Bolt Clamping Length (calculated)
DTCLWA
real
Bolting Washer Clearance
DTCNST
element
Detailing Zone/Phase Designer
DTCNTC
element
Detailing Job Customer Contact Person
DTCNTY
string(80)
Detailing Address Country
DTCNUM
integer(100)
Bocad Detailing Comment Number
DTCOLA
string(80)
Primary Color
DTCOLB
string(80)
External Color
DTCOLN
element
Nested Drawing Reference
DTCOLO
integer
Dimension text colour
DTCONU
integer
Dimension text colour number
DTCORF
element(100)
Reference to Bocad Detailing Comment Container
DTCSAG
real
Sink Hole Angle
DTCSDA
real
Sink Hole Diameter 1
DTCSDB
real
Sink Hole Diameter 2
DTCSDC
real
Sink Hole Diameter 3
DTCSHD
real
Sink Hole Dimension Head
DTCSIV
logical
Countersunk Bolt
DTCSNU
real
Sink Hole Dimension Nut
DTCTLN
real
Detailing Item Cut Length
DTCUST
element
DTCUTY
integer
Detailing Fabrication Item / Type of cut, 0 = no, 1 = standard cuts, 2 = cutouts-notch
DTDBST
string(80)
Detailing Job Database State
DTDDTE
datetime(2)
Detailing Job Delivery Date
DTDESI
string(80)
Designation
DTDESR
element
Reference to Bolt Set Designation Container
DTDINN
integer
Detailing Element DIN Number
DTDISA
real
Section Distance 1
DTDISB
real
Section Distance 2
DTDLIM
logical
Blind Hole Bolt
DTDMAT
logical
Clamp Length Calculation Flag
DTDRST
integer
Detailing Drawing Status
DTDRTY
integer
Detailing Drawing Type
DTDTEN
string(80)
Detailing End Date
DTDTST
string(80)
Detailing Start Date
DTDVIS
logical
Visible in base dimetry
DTEDAT
integer(90)
Detailing Model Element Attributes
DTEMAL
string(80)
Detailing Person eMail Address
DTER
string
Dimension terminator code
DTERID
integer
Dimension terminator ID
DTERSA
integer
Dimension term. code style angular DTERSA
DTERSL
integer
Dimension term. code style linear DTERSL
DTERSR
integer
Dimension term. code style radiant DTERSR
DTETYP
integer
Detailing Element External Type Code
DTFCOA
string(80)
Detailing Final Coating
DTFEAG
element
Reference to a Feature Group/Set
DTFEAR
element
DTFEAS
element(100)
References to Feature Values
DTFL
string
Dimension text radius flag
DTFLTY
integer
BMF Folder Type
DTFLWB
real
Detailing Fabrication Item / Partial cut/cutout - angle Flange/Left/bottom
DTFLWT
real
Detailing Fabrication Item / Partial cut/cutout - angle Flange/Left/top
DTFLXB
real
Detailing Fabrication Item / Partial cut/cutout - x value Flange/Left/bottom
DTFLXT
real
Detailing Fabrication Item / Partial cut/cutout - x value Flange/Left/top
DTFPHN
string(80)
Detailing Person FAX Phone number
DTFPO
string(100)
Final painting 1
DTFPT
string(100)
Final painting 2
DTFREA
string(80)
Bocad Detailing Free Attribute 1
DTFREB
string(80)
Bocad Detailing Free Attribute 2
DTFREC
string(80)
Bocad Detailing Free Attribute 3
DTFRED
string(80)
Bocad Detailing Free Attribute 4
DTFREE
string(80)
Bocad Detailing Free Attribute 5
DTFRWB
real
Detailing Fabrication Item / Partial cut/cutout - angle Flange/Right/bottom
DTFRWT
real
Detailing Fabrication Item / Partial cut/cutout - angle Flange/Right/top
DTFRXB
real
Detailing Fabrication Item / Partial cut/cutout - x value Flange/Right/bottom
DTFRXT
real
Detailing Fabrication Item / Partial cut/cutout - x value Flange/Right/top
DTFSIZ
integer(2)
Detailing Model Folder Sizes
DTFTHK
real
Detailing Element Flange Thickness
DTFUNC
integer
Detailing Element Function Code
DTGALV
string(80)
Detailing Galvanisation Type
DTGATT
real(10)
Detailing Model Attributes Real part
DTGCNT
integer
Detailing Element Generated Count
DTGEND
integer
Detailing Element Generation Date
DTGID
integer
Detailing Model geoemetry ident number
DTGLEN
integer
Detailing Element Generation Length
DTGNIF
integer
Bolt Hole Orientation Mode
DTGRADE
string(32)
Detailing Material Grade
DTGRDS
element(99)
References to Detailing Job Grid Definitions
DTGTRI
real(12)
Detailing Creation Tripod
DTGTYP
integer
Detailing Element Geometry Type Code
DTHDHE
real
Bolt Header Height
DTHEIG
real
Detailing Element Height
DTHGTH
real
Height
DTHOTY
integer
Bolting Hole Type
DTIDAT
integer(120)
Detailing Model Attributes Integer part
DTINAX
logical
Seamline in Axis Direction
DTIT
string(32)
Data Title
DTITYP
integer
Detailing Element Internal Type Code
DTJDSC
string(80)
Detailing Job Description
DTJLOC
element
Detailing Job Location
DTJNUM
string(80)
Bocad Detailing Job Number / Name
DTJREV
string(80)
Detailing Job Revision
DTLEAD
element
Reference to Lead Part
DTLELE
element(5000)
Datal Elements list
DTLEN
integer
Detailing Element Length
DTLGTH
real
Detailing Fabrication Element Length
DTLH
real
Dimension text letter height
DTLHTX
string(80)
Dimension text letter height text
DTLLIST
word(2000)
Datal Attributes List
DTLNAM
real
Detailing Item Length after Marking
DTLNGE
real
Detailing Item generated Length
DTLPDO
element
Reference to Original main part
DTLPDZ
element
References to Additional Part
DTLPHN
string(80)
Detailing Person Landline Phone number
DTLTST
integer(8192)
Datal Test attribute
DTMAT
string(80)
Fabrication Material
DTMDFD
string(19)
Modified Date/Time
DTMDST
datetime(2)
Modification Date
DTMFKE
integer
Detailing Element Manufacturing ID
DTMFST
datetime(2)
Manufacturing Status Date
DTMIND
integer
Bolt Connection Processing Mode
DTMKIN
string(80)
Initial Mark Number
DTMKPR
string(80)
Previous Mark Number
DTMKTX
string(80)
Mark Text
DTMMDE
integer
Detailing Element Marking Status / Mode
DTMODD
integer
Detailing Element Modification Date
DTMODF
string(80)
Modfied by
DTMPAR
element
Reference to original mirror element
DTMPHN
string(80)
Detailing Person Mobile Phone number
DTMPMA
real
Design temp. max
DTMPMI
real
Design temp. min
DTMTYP
integer
M3 Connection Type
DTNAME
string(80)
Detailing Item Name
DTNBEN
integer
Detailing Fabrication Item / Quantity of bends
DTNCHA
integer
Detailing Fabrication Item / Quantity of chamfers
DTNHOL
integer
Detailing Fabrication Item / Quantity of holes
DTNICO
integer
Detailing Fabrication Item / Quantity of inner contours
DTNMOD
integer
Detailing Fabrication Item / Quantity of modification on the geometry. Notches, Cuts, Cutoffs...
DTNMPO
integer
Detailing Fabrication Item / Quantity of marking points
DTNNOT
integer
Detailing Fabrication Item / Quantity of notches
DTNSEA
integer
Number of Seam Angles
DTNSEC
integer
Number of Seamline Sections
DTNSEL
integer
Detailing Fabrication Item / Quantity of superelevation
DTNSHO
integer
Detailing Fabrication Item / Quantity of slotted holes
DTNSWE
integer
Detailing Fabrication Item / Quantity of welds, site
DTNUMB
integer
Detailing Model Element ident number
DTNWWE
integer
Detailing Fabrication Item / Quantity of welds, workshop
DTOF
real(2)
Dimension text offset
DTOFTX
string(80)
Dimension text offset text
DTOHDD
real
Outside Bolt Header Diameter
DTOP
real
Top diameter
DTOPOS
integer
Detailing Element Order Item Number
DTOREL
element
Reference to Original Element
DTPART
element(10)
Bolt Set Component References
DTPBOX
string(80)
Detailing Model Address Post Box
DTPCNO
integer
Number of raw Contour Points
DTPCNT
integer
Number of Points
DTPELM
element
Reference to Parent element
DTPFAM
integer
Point Family
DTPMAN
element
Detailing Job Project Manager
DTPN
integer
Dimension text pen
DTPOSN
integer
Detailing Element Item / Mark Number
DTPPO
string(100)
Primary painting 1
DTPPT
string(100)
Primary painting 2
DTPREF
string(80)
Mark Number Prefix
DTPRFL
integer
Detailing Model Relation Primary Flag
DTPRIM
element
Reference to relation-carrying element
DTPRIN
string(80)
Initial Profile Type
DTPROT
real
Bolt Protrusion
DTPRTS
element(100)
References to auxiliary node elements
DTPSTL
element
Reference to Parent Element BOM item
DTPTCN
integer
Bolt Set Part Count
DTPTSQ
integer
Bolt Set Part Sequence Number
DTPUNI
integer
Bolt Packing Unit
DTRA
real
DTRADA
real
Detailing Element Fillet Radius 1
DTRADB
real
Detailing Element Fillet Radius 2
DTRADC
real
Detailing Element Fillet Radius 3
DTRATX
string(80)
Dimension text radius text
DTRDAT
real(100)
DTRE
element
Data set reference
DTREAS
element
Reference to element creating the relation
DTREVH
string(80)
Revision Index History
DTREVI
string(80)
Revision Index
DTRFPA
integer
Detailing Element Ref. Information 1
DTRFPB
integer
Detailing Element Ref. Information 2
DTRLEN
real
Factory Standard Part Length
DTROOA
real
Detailing Element Root Dimension 1
DTROOB
real
Detailing Element Root Dimension 2
DTROOC
real
Detailing Element Root Dimension 3
DTRPAR
element
Reference to replacement element
DTRTRI
real(12)
Detailing Reference Tripod
DTRWHG
real
Detailing Element Remaining Webbing Height
DTSAAS
real
Detailing weld throat depth (arrow side)
DTSANG
real(10)
Seamline Section Angles
DTSAOS
real
Detailing weld throat depth other side
DTSCAL
string(80)
Detailing Scalding
DTSCAN
logical
Bolt Hole Investigation Flag
DTSCST
string(80)
Detailing Job System Data / Customer
DTSDTE
datetime(2)
DTSECN
integer
Seamline Section Number
DTSECS
element(100)
Reference to parts in the relation
DTSEFL
integer(100)
Detailing Model Relation Secondaries Flags
DTSET
logical
Bolt Set Flag
DTSHTR
element
Reference to Shop Transformation element
DTSIZE
integer
Detailing Model BLOB Size
DTSKEY
string(32)
Bolt Standard Key
DTSLEN
real
Saw Length
DTSMAT
logical
Include Bolt Mounting Material
DTSNUM
integer
Section number (cladding)
DTSPOS
integer
Start number for marking
DTSRCE
element
Reference to Source Element
DTSTAT
integer
Detailing Element Status
DTSTRE
string(80)
Detailing Model Street Address
DTSTTE
string(80)
Detailing Address Element State
DTSTYP
integer
Detailing Element Shape Type Code
DTSURF
string(32)
Detailing Surface Treatment
DTTAPE
integer
Tapered Washer Mode
DTTCNT
integer
Detailing Element Total Count
DTTDAT
element(20)
Bocad Detailing Element Text
DTTKMO
integer
Detailing Element Model ID
DTTLNU
integer
Number of truck load
DTTOTL
real
Total Bolt Length
DTTSNR
integer
Detailing Element Phase Number
DTTXNX
integer
Fabrication model element text sequence number
DTTXRF
element(100)
Bocad Detailing Text Reference
DTTXT
string(320)
Bocad Detailing text data
DTTYPE
integer
Detailing model item type
DTUKST
datetime(2)
Documentation ID Date
DTUL
string
Dimension text underlining flag
DTULKE
integer
Detailing Element Documentation ID
DTUNIT
integer
Bolt Dimension Units
DTUWGH
real
User weight (ruberband method)
DTVALI
integer
Detailing Feature Value Index
DTVBKY
string(32)
Bolt Fastener Table Key
DTVERS
integer
Job Element Version Number
DTVIDD
logical
Bolt always as 3D body
DTVOLM
real
Assembly volume
DTWDTH
real
Width
DTWGHT
real
Weight
DTWIDT
real
Detailing Element Width
DTWLDR
element
Reference to a weld definition element
DTWLRF
element
Reference to Weld Element
DTWLWB
real
Detailing Fabrication Item / Partial cut/cutout - angle Web/Left/bottom
DTWLWT
real
Detailing Fabrication Item / Partial cut/cutout - angle Web/Left/top
DTWLXB
real
Detailing Fabrication Item / Partial cut/cutout - x value Web/Left/bottom
DTWLXT
real
Detailing Fabrication Item / Partial cut/cutout - x value Web/Left/top
DTWRWB
real
Detailing Fabrication Item / Partial cut/cutout - angle Web/Right/bottom
DTWRWT
real
Detailing Fabrication Item / Partial cut/cutout - angle Web/Right/top
DTWRXB
real
Detailing Fabrication Item / Partial cut/cutout - x value Web/Right/bottom
DTWRXT
real
Detailing Fabrication Item / Partial cut/cutout - x value Web/Right/top
DTWSIZ
real
Bolt Header Wrench Size
DTWTCL
string
Date of weight/cog calculation
DTWTHK
real
Detailing Element Webbing Thickness
DTXR
string(2000)
RTEXT of detailing text
DTXRGB
integer(4)
RGB dimension text colour
DTXRGP
integer(4)
RGB dimension text colour physical
DTXS
string(2000)
STEXT of detailing text
DTXT
string(2000)
TTEXT of detailing text
DTXVEC
dir
Detailing View Volume X-Axis
DTYVEC
dir
Detailing View Volume Y-Axis
DTZGRD
element
Detailing Zone Primary Grid
DTZIPC
string(80)
Detailing Model Address ZIP code
DTZNUM
integer
Bocad Detailing Zone Number
DTZPLN
element
Detailing Zone View Volume
DTZPOS
real
Z Offset of the view plane
DTZVEC
dir
Detailing View Volume Z-Axis
DUCTHE
real
Default duct height
DUCTSH
word
Default duct shape
DUCTWI
real
Default duct width
DUNI
word
Distance units
DUNION
integer
DRAFT element union detail flag
DUPLIC
element(10000)
integer
Duplicates of the current element with the same attribute values
DUTY
string(120)
Duty
DVFL
logical
ADP detail views flag
DVSCL
real(500)
ADP detail view allowable scale list
DVTH
real
ADP detail views threshold
DWALLT
real
Derive wall thickness
DWDIR
dir
Draft world direction for pline or ppoint
DWGF
string(73)
DWG filename (No suffix)
DWID
string(1000)
Width offset
DWINSI
real
Default Window Sill
DWPOS
pos
Draft world position for pline or ppoint
DX
string(1000)
Cartesian X offset
DXL
string(1000)
Incremental X length
DXYOFF
real(2)
DRAW 2D Offset
DY
string(1000)
Cartesian Y offset
DYL
string(1000)
Incremental Y length
