Data Model
Introduction to Attributes
List of All Attributes
: Attribute C
Attribute C
Attribute Name
Data Type
Qualifier
Description
CABBOX
real(6)
Calculated box volume in world coordinates
CABCOL
string(120)
Cable colour
CABGAP
real
cable gap on cabletray as multiple of OUTD
CABINT
string(120)
cable interference class
CAGOFF
real
Cage Offset
CAGSIZ
real
Cage Size
CANDRM
logical
Can drum
CAPTIO
string(120)
Caption
CARD
integer(2)
Cardinality definition
CARE
string(12)
Isodraft Compipe: Area
CASELIST
!UNKNOWN(100)
attr
List of cases set for a UDA
CASENAME
string(120)
Case Name
CASENM
string(120)
Case Name
CASR
element
Case reference
CATANO
string(120)
Text storing unique display name for Cable
CATMOD
integer
Catalogue Geometry Modified- Not directly query able
CATR
element
Catalogue reference
CATTEX
string(725)
Concatenation of Detailing and Material Texts
CATUSR
element
Category owner
CATY
integer
Card type
CAXISE
string
Coordinate axis enumerated
CAXISI
integer
Coordinate axis
CBACXR
real
integer
Accumulated cables xarea at route node
CBCOG
pos
Cable centre of gravity
CBCULE
real
Cut Length of cable
CBFRLE
real(20)
Free Length of cable
CBGELE
real
Geometric Length of cable
CBNUCW
element(500)
Cables at a point on a cableway
CBPOSA
real(2)
First cut bridge definition point
CBPOSB
real(2)
Second cut bridge definition point
CBPREF
element(500)
References to POINTR forming route of a cable
CBRNLS
element(500)
List of route nodes that cable passes
CBRRLS
element(500)
List of route nodes and rattas that cable passes
CBRWGL
real
Raw Geometric Length of cable
CBSTA
integer
Cable routing status
CBSTA
string(700)
integer
Cable routing status text
CBSTT
string(10)
Cable status text
CBTOLE
real
Total Length of Cable
CBWEIG
real
Cable weight
CCEN
integer
Cost centre
CCLA
integer
Cost class
CCOL
integer
Colour (in catalogue)
CCON
word
Connection type
CCOREF
element
Cable core set reference
CCORRE
element
Cable Core set reference
CCORXR
element(500)
Return reference from CCORSET element to SCOMs
CDET
element
Catalogue detail
CDIST
real
CurveDistance
CDPL
word(100)
List of valid current design properties
CDPR
real
word
Current design dataset property
CDRG
string(24)
Isodraft Compipe: Drawing number
CELLID
integer(2)
Cell Identifier
CELLTO
real
Total Number of Cell
CELLTR
real
Total Number of Trimmed Cells
CELLWH
real
Total Number of Untrimmed Cells
CELREF
element
Status Element reference
CEND
string
Connection at other end of CREF (HEAD or TAIL)
CENGRA
pos
Factory Standard Part Centre of Gravity
CENRADIUS
real
Centreline Radius
CERF
element(500)
Array of Faces generated by this
CEXES
real(4)
Cable excesses
CEXS
real
Percentage excess for passing cables
CFCHE
logical
Fill level check
CFDP
element
word
CFFA
element(500)
CFGCTX
string(120)
Configuration key context
CFGEO
real(8)
Cut free definition curve
CFGIAV
integer(2147483647)
Configuration integer array value
CFGIV
integer
Configuration integer value
CFGKRE
element
Configuration key reference
CFGLAV
logical(2147483647)
Configuration logical array value
CFGLV
logical
Configuration logical value
CFGNAM
string(50)
Configuration key name
CFGOVR
logical
Configuration Override Flag
CFGRAV
real(2147483647)
Configuration real array value
CFGRV
real
Configuration real value
CFGTAV
!UNKNOWN(2147483647)
Configuration text array value
CFGTV
string(2048)
Configuration text value
CFGTYP
string(120)
Configuration value type
CFILL
real
Fill level at route node
CFKEYP
string(2000)
Configuration key path
CFRA
element(10)
Cofitting reference array for Pfittings
CGROFF
real
Grid position offset
CGrPos
integer(100)
Coordinate grid positions
CHALEN
real
Length of chamfer intervals
CHAM
real(2)
Chamfer lengths
CHANUM
integer
Number of chamfer intervals
CHAR
integer
Character set
CHARGE
string(75)
Charge
CHCOLO
integer
Dimension crosshairs colour
CHCONU
integer
Crosshairs colour number
CHCRGB
integer(4)
RGB dimension crosshairs colour
CHCRGP
integer(4)
RGB dimension crosshairs colour physical
CHDCOLUMN
element
Child column
CHECKE
string(1000)
Checker
CHEI
real
Character height
CHEIGL
real
GLabel style character height
CHEITX
string(80)
Character height text
CHKDAT
string(120)
Date checked
CHKSUM
string(32)
MD5 checksum
CHNGD
integer
Changed counter
CHOS
real
Crosshairs overshoot
CHOSTX
string(80)
Crosshairs overshoot text
CHPN
integer
Crosshairs pen
CHSTREF
element
Crosshairs linestyle Reference
CHSTYL
integer
CIMPED
real
Conductor impedance
CIRCR
real(4)
Circumscribed rectangle
CIWE
string(1000)
Total insulation weight
CKEY
word
ISODRAFT end condition key
CLADNO
string(120)
Additional notations
CLAI
integer
Claim mode
CLAIMDB
string(10)
Implicit or explicit claims
CLALEN
real
clamping length
CLANAM
!UNKNOWN(10)
Class Name
CLBASE
real
Column base offset
CLCCNT
integer
Claim list changes count
CLCOLO
integer
Centreline colour
CLCONN
element(5000)
integer
Elements that Clasher considers to be connected (and hence no clashes)
CLCONU
integer
Centreline colour number
CLCUTO
real
Cutting length cutouts
CLEIB
real
Cutting length end, no bevel or butt
CLEVB
real
Cutting length end, V bevel
CLEXB
real
Cutting length end, X bevel
CLEYB
real
Cutting length end, Y bevel
CLFG
logical
Centreline flag
CLFL
logical
Centreline flag
CLGRND
real
Total grinding length
CLHO
real
clearance hole
CLHOLE
real
Cutting length holes
CLHULL
string(120)
Hull
CLICEC
string(120)
Ice class
CLIPCD
integer
Clip code
CLIST
element(500)
integer
All cables attached to route node
CLLE
real
Branch centreline length
CLLENA
real
First corner loop length
CLLENB
real
Second corner loop length
CLMACH
string(120)
Machinery
CLMID
string(120)
Unique system ID of user claiming element
CLMIDL
string(256)
Unique system ID of user claiming element (long)
CLMNUM
integer
User or extract number claiming element. Extract numbers are negative
CLMO
string
Centreline mode: 1=CL OFF, 2=CL ON
CLMPLN
real
Clamping length of manufactured profile
CLMRGB
integer(4)
RGB column colour
CLMRGP
integer(4)
RGB column colour physical
CLMTIE
element(4)
Reference to elements that are automatically claimed along with this element
CLNCOD
string(120)
Ceiling Code
CLNELE
real
Ceiling Elevation
CLNELS
element(100)
References to panels or components in the same clone chain
CLNFAC
real
Cleaning factor
CLNHEI
real
Ceiling Height
CLNOTC
real
Cutting length notches
CLNREF
element(100)
References to clones of this element
CLNRGB
integer(4)
RGB centreline colour
CLNRGP
integer(4)
RGB centreline colour physical
CLNTYP
string(120)
Ceiling Type
CLNVOI
real
Ceiling Void Height
CLOSED
logical
True if plate covering entire referenced component
CLOSEFLAG
logical
True if branch is closed
CLPN
integer
Centreline pen
CLPOS
real(2)
Corner loop definition point
CLRAD
real
Corner loop radius
CLRF
element
Actual circulation list reference
CLRISS
logical
Clear lower parts on issue
CLRSIZ
real(2)
Clearance size
CLSARE
string(120)
Service area
CLSNAM
string(120)
Class Name
CLSTREF
element
Centreline linestyle Reference
CLSTYL
integer
CLTOT
real
Total cutting length
CLTRID
integer
Cloning transformation composition index
CLUTCH
word
Bending machine insertion direction
CMALL
real
Structure allowance
CMAXF
real
Calculate maximum fill level on cway
CMBOUA
element
Aft boundary
CMBOUF
element
Fwd boundary
CMBOUL
element
Lower boundary
CMBOUP
element
Ps boundary
CMBOUS
element
Stbd boundary
CMBOUU
element
Upper boundary
CMBOX
real(6)
Bounding box
CMCAT
string(256)
Compartment category
CMCDE
real
Content density
CMCTID
string(256)
Content type ID
CMDESC
string(256)
Compartment description
CMFLW
real
Full Load Weight
CMINF
real
Calculate minimum fill level on cway
CMLCV
real
Longitudinal centre of total volume
CMMGE
integer
Merged compartment indicator
CMNTID
string(32)
Detailing Comment ID
CMPER
real
Compartment permeability
CMPERD
real
Permeability for use in damage
CMPLNK
element
Return reference from schematic or design element to CYMLNK element
CMPR
element
Component reference
CMPRFA
element(500)
All components for the PipePiece
CMPSTATUS
word
Connectivity comparison status
CMPSTS
string(120)
Connectivity comparison status description
CMPURP
string(256)
Purpose
CMTCV
real
Transverse centre of total volume
CMTYP
integer
Type of compartment
CMVCV
real
Vertical centre of total volume
CMVOL
real
Total volume
CNSTRF
element
Connector style reference
CNTNUM
integer
Contour number
CNTYPE
integer
Contour Type Number
CNUM
string(22)
Isodraft Compipe: Line number
COCDRE
element(500)
word
COCDESS with same COCONN value as qualifier
COCONN
word
COCO Connection type
COCORE
element(2)
COCO description reference
COCOXR
element(500)
COCO description return reference
COCSAM
element(500)
COCOS with same CTYP value as COCDES
COFF
real
Offset
COFVEC
real(3)
Curve Vector
COLCOL
integer
Column colour
COLCON
integer
Column colour number
COLNUM
integer
Pin column number
COLRGB
integer(4)
RGB colour
COLRGP
integer(4)
RGB colour physical
COLSCH
string(120)
Color Schema
COLSTREF
element
Column linestyle Reference
COLSTY
integer
Column linestyle
COLXSP
real(100)
Spacing between columns in the X direction of the tower
COLYSP
real(100)
Spacing between columns in the Y direction of the tower
COMBOO
word
Boolean Combination
COMM
string(120)
Comment
COMMST
string(500)
Comment string
COMNT
string
Comment
COMPEN
logical
Compensate bending activities for springback
COMPID
integer(100)
Component identity
COMPRE
element
Supported component reference
COMPTYPE
word
Type of component
COMSTA
string(256)
Comment string 1
CONAM
string
Cutout name
CONARR
word(10)
Connection array
CONATS
element(500)
List of attachment connected to attachment
CONATT
string(5000)
Referenced conceptual model attribute
CONBRA
element(500)
List of branches connected to branch
CONCD
integer
Connection code
COND
integer(500)
Access Control Logical condition
CONDES
string
Connection string
CONDGR
integer
No of Conductor Groups
CONERF
element
Connection End Ref
CONMTL
element
Conductor material
CONNE
logical
Segment end connection flag
CONNECTIONS
element(5000)
Connections
CONNECTIONSH
element(5000)
Connections for all descendants
CONNECTSERVICEID
string(120)
Connect service ID of the uploaded project in cloud
CONNER
string(300)
integer
Connection error message
CONNRE
element(10)
References to other element
CONNS
logical
Segment start connection flag
CONREF
element
References to other connected element
CONRF
element
Connector reference
CONSIS
logical
Position consistency
CONSRF
element
Connection Start Ref
CONSUPPORTS
element(500)
All connected supports to the element tree under an element
CONTRA
element(500)
List of trays connected to branch
CONTYP
string
Connection type
COPI
integer
Number of copies
COPYDB
element(8191)
Copies of this database
CORA
string(1000)
Corrosion thickness
CORCGR
string(120)
integer
cable core conductor group
CORCOD
string(120)
Core code
CORCOM
string(120)
Core composition
CORCON
element(50)
COR Configurations
CORGRP
integer
Core Group
CORNUM
integer
Corner number
CORNUV
pos
Corner point
CORROS
real
Tube corrosion
CORRUG
logical
True if corrugation is defined on the plate part
CORSZ
real
Size of the core
CORTAG
string(120)
integer
cable core tag
CORTYP
string(120)
Core type
COSTES
string(256)
Cost estimator
COUN
integer
Counter
COVHOL
logical
Cover hole
CPAR
real(100)
Catalogue parameters
CPARTS
element(4)
Connection parts
CPEN
integer
Pen for internal columns
CPFA
element(500)
Array of Ports this points to
CPHASE
element
Reference to Construction Phase
CPLO
string(120)
Plot (in catalogue)
CPOF
real(2)
Leaderline connection point wrt. text origin
CPOFTX
string(80)
Leaderline connection point text
CPOS
pos
conditioning position for curve geometry
CPRIND
word(2)
Connection point instance repeat index
CPRIO
integer
Connector priority flag
CPRO
real
Spot value of property C
CPSDAT
blob(2147483647)
CPS Data
CPSRCR
element
Connection point instance source reference
CPUL
real(3)
Cold pull - translational
CPUT
real(3)
Cold pull - twist
CRCANG
real
Turning angle for least circumscribed rectangle
CRCLW
real(2)
Length and width of least circumscribed rectangle
CRDATE
string(120)
attr
Date element created in current DB or if extract in ascendant
CREACT
real
Conductor reactance
CREANCESTORS
logical
Create ancestors
CREF
element
Connection reference
CRESIS
real
Conductor resistance
CREXTR
integer
attr
Extract element created in current DB or if extract in ascendant
CRFA
element(10)
Connection reference array
CRINFO
string(200)
DB creation information
CRIT
integer(250)
Selection criteria (used to define tag & rep. rules)
CRSAOS
element
Symbolic cross section abut other side style reference
CRSATS
element
Symbolic cross section abut this side style reference
CRSESS
integer
attr
Session element created in current DB or if extract in ascendant
CRSNR
element
Symbolic cross section style reference
CRSOS
element
Symbolic cross section other side style reference
Crspn
element
Symbolic cross section penetration style reference
CRSTHS
element
Symbolic cross section this side style reference
CRUSER
string(120)
attr
User created element in current DB or if extract in ascendant
CSESS
string(640)
integer
Comment entered for specified session
CSFBR
logical
Spooling marker for components
CSGBOX
real(6)
CSG-Calculated box volume in world coordinates
CSPA
real
Character spacing factor
CSPATX
string(80)
Character spacing factor text
CSPC
string(6)
Isodraft Compipe: Specification
CSTA
string(120)
Catalogue Standard
CSTMER
string(256)
Customer
CSTMRN
string(256)
Customer number
CSTR
element
Constraint reference
CTCREF
element
integer
Cable tray component ref
CTHATP
integer
Commenting attachment purpose
CTHCFC
element
Closed LOV reference
CTHCFO
element
Open LOV reference
CTHCTP
string(120)
Commenting content type
CTHICK
real
Coating thickness
CTHID
element
Thread Id
CTHLIS
element(500)
List of attached comment threads
CTHMAS
element
Commenting world Master reference
CTHREF
element
Comment Element reference
CTHSEL
integer(500)
Selection expression
CTHSTA
integer
Commenting thread state (Open/Close)
CTHSTT
string(20)
Thread state text
CTHTEX
string(1000)
Commenting text
CTHTOL
element(500)
List elements assigned to a comment threads
CTHWLI
element(20)
List of Commenting worlds
CTSPE
element
Cable tray specification
CTTYP
word
Cable tray typ
CTXPSP
integer
Connector Text Position (ByVStyle, Centre, Start, End)
CTXT
string(120)
Card text
CTXTPS
string(120)
Connector Text Position (as text)
CTYA
word
Attached connection type
CTYE
word
End connection type
CTYO
word
Owning connection type
CTYP
word(2)
Connection type
CTYPLI
word(5000)
List of COCO Ctypes
CTYS
word
Start connection type
CUALWD
logical
Indicates compare update window is allowed
CURD
element(5000)
Current DBs
CURF
string
Curve fitting code: 1 default, 2 cubicfit
CURLOC
element
True current location
CURNAM
string(120)
Curve Name
CURREN
string(1000)
Current
CURRFULL
element(5000)
List of current DBs in MDB, expanding DBsets
CURTYP
word
Curve type
CURVED
logical
True if curved plate part.
CUSDIR
logical
Curve Segment Direction Start to End
CUSOFF
real
Curve Segment Offset
CUSRAD
real
Curve Segment Radius
CUSVAL
string(4000)
Delimited Custom Value List
CUTALW
real
Cutting allowance
CUTB
real
Cutback
CUTL
real
Cut length
CUTLAR
real(50)
Cut Length Array
CUTMIN
real
Cutting allowance minimum length
CUTNAM
string(700)
integer
Full name of element, truncated to n characters
CUTNMN
string(700)
integer
Full name of element (without leading slash) truncated to n characters
CUTP
dir
Cutting plane normal
CUTVEC
dir
Cut plane normal
CVALS
real(100)
Coordinate values
CWEI
string(1000)
Total component weight
CWHEAD
element(500)
Cableway Head
CWHPOS
pos
Cableway path head point position
CWIDTH
real
Clearance Width
CWJBLS
element(500)
Cableway branches and junction boxes list
CWJUSL
word
Cable Way Justification Line
CWLIST
element(500)
All cableways attached to route node
CWPPJB
element(500)
Cableway branches and pull pits and junction boxes list
CWPPLS
element(500)
Cableway branches and pull pits list
CWTAIL
element(500)
Cableway Tail
CWTPOS
pos
Cableway path tail point position
