Data Model
Introduction to Attributes
List of All Attributes
: Attribute A
Attribute A
Attribute Name
Data Type
Qualifier
Description
AALLAN
real
Arrive Ppoint allowed angle
AANGXZ
real
Angle of attached SCTN in XZ plane of joint
AANGYZ
real
Angle of attached SCTN in YZ plane of joint
ABLE
integer
Minimum abbreviation length for a UDA/UDET user defined name
ABOP
pos
Bottom of arrive pipe
ABOR
real
Arrive bore
ABRE
string(8)
Abbreviation
ACBO
string(1000)
Actual bore
ACBTEX
string(500)
AutoCAD annotation text
ACBTYP
string(180)
AutoCAD annotation type
ACCDIR
dir
Access Direction
ACCELE
real(500)
Elevations of Referenced Levels
ACCESSDB
string(10)
DB access
ACCIDENT
real
Accident level radiation
ACCLEV
real(100)
Access Heights for Stairwell
ACCREF
element
Reference to Access element
ACCTYP
word
Access type
ACDATE
string(50)
Date last modified in AutoCAD
ACDMTX
string(500)
AutoCAD dimension text
ACDSTY
string(120)
AutoCAD Dimension style
ACDTYP
string(180)
AutoCAD dimension type
ACDWT
string(120)
AutoCAD drawing template name
ACEXPO
string
AutoCAD export flag
ACLASS
word(100)
Access Control Attribute class
ACLAYE
string(120)
AutoCAD layer name
ACLIST
element(500)
Arriving cables to attached point
ACLOCK
string
AutoCAD picture lock
ACNAME
string(120)
AutoCAD name
ACON
word
Arrive connection type
ACORRO
real
Arrive corrosion allowance
ACPICT
string
Everything3D DRAW picture
ACPLTX
string(500)
AutoCAD projection line text
ACPO
element
Access port reference
ACPTYP
string(180)
AutoCAD projection line type
ACRF
element
ACR reference attribute
ACRGRP
element(5000)
List of ACRs within a ACRSET
ACRLI
element(300)
Access Control User assigned ACRs
ACRMESSAGE
string(120)
Access Control User defined message
ACSCAL
real
AutoCAD picture scale factor
ACSTYF
element
Annotation change style reference
ACTANG
real
Actual angle of a bend
ACTIV
logical
Active
ACTL
real
Actual length
ACTNCU
integer
Actual number of cuts of a bend
ACTRAD
real
Actual radius of a bend
ACTTYPE
word
Type of element, truncating non UDETs to 4 or 6 characters
ACTXRF
element
Annotation Context Reference
ADDMHE
string(32)
Detailing Bolt Set Head-Side Addtl. Material
ADDMNU
string(32)
Detailing Bolt Set Nut-Side Addtl. Material
ADDSEGMENTS
logical
Auto creating segments flag
ADEFRF
element
Reference to master ASSDEF
ADEG
real
Orientation
ADEN
real
Addition factor (unit definition)
ADESP
real(100)
Design parameters of attached element
ADIR
dir
Arrive direction
ADMLOC
element
Currently administered location
ADPRFA
element(500)
ADP reference array
ADUUID
string(40)
UUID to ensure Project uniqueness
AELRFA
element(500)
Boundary components for the PipePiece
AEXCES
real
Arrive excess for leave tube
AFPARA
real(100)
Auxiliary function parameters
AFTEXT
string(400)
Auxiliary function
AGATYINT
integer
Auto Grid Annotation Type (ByVStyle, ViewFrame, Local)
AGATYPE
string(120)
Auto Grid Annotation Type (as text)
AGDCLINT
integer
Auto Grid Annotation Closed Dimensions (ByVStyle, Off, On)
AGDCLOSED
string(120)
Auto Grid Annotation Closed Dimensions (as text)
AGDMSTYLE
element
Auto Grid Annotation Dimension style reference
AGDOFFSET
string(80)
Auto Grid Annotation Dimension Offset
AGDOFREAL
real
Auto Grid Annotation Dimension Offset real
AGDOOFFSET
string(80)
Auto Grid Annotation Overall Dimension Offset
AGDOOREAL
real
Auto Grid Annotation Overall Dimension Offset real
AGDOVINT
integer
Auto Grid Annotation Overall Dimensions (ByVStyle, Off, On)
AGDOVR
string(120)
Auto Grid Annotation Overall Dimensions (as text)
AGDVRT
string(120)
Auto Grid Annotation Vertical Dimensions (as text)
AGDVTINT
integer
Auto Grid Annotation Vertical Dimensions Integer (ByVStyle, Off, On)
AGLESTYLE
element
Auto Grid Annotation Elevation Label style reference
AGLETM
element
Auto Grid Annotation Elevation Label Template Reference
AGLFSTYLE
element
Auto Grid Annotation Face Label style reference
AGLFTM
element
Auto Grid Annotation Face Label Template Reference
AGLOFFSET
string(80)
Auto Grid Annotation Label offset
AGLOFREAL
real
Auto Grid Annotation Label offset real
AGMODE
string(120)
Auto Grid Annotation Mode (as text)
AGMODINT
integer
Auto Grid Annotation Mode (ByVStyle, Off, Labels, Dimensions, All)
AGRD
real
Arrive Ppoint gradient
AGSIDE
string(120)
Auto Grid Annotation Sides
AGSIDINT
integer
Auto Grid Annotation Sides Integer
AHLIS
word(200)
List of actual types in owning hierarchy
AIRCHA
real
Air Change Rate
AIRT
string(120)
Air tight control method
AKEY
word
Attribute key
AKEYL
word(20)
Attribute-keylist (for Radial dimensions)
ALCODE
integer(10)
Alarm code array
ALENGTH
real
Arrive length
ALIGN
string
Vertical alignment
ALIST
element(500)
ALLANG
string(1000)
Connection allowable rotational angle
ALLELE
element(10000)
elemtype
All elements in the MDB of a particular type
ALLO
real
Allowance
ALTDEF
element
Alternative Def
ALWDEL
logical
To allow the admin user to determine if tags can be deleted
ALWREN
logical
Allow Rename
ALWUSE
logical
Indicates whether or not catalogue can be used in the project
AMAPNM
string(120)
Local Name of Proxy actual member
AMEMRF
element
Reference to a design model object
AMPMPN
string(120)
Local Name of Proxy in Association
AMTEMP
real
Ampacity Temperature
ANGFR
real
Angle between assembly and frame plane
ANGL
real
Angle
ANGLSP
real(10000)
ANGLE Spacing
ANGSEG
real(2)
Angle segment (start,end)
ANGSPA
real
Springback angle at 20 degrees
ANGSPB
real
Springback angle at 120 degrees
ANGWL
real
Angle between assembly and water-line plane
ANPJ
pos
Attached neutral point of joint (steelwork)
ANPS
pos
Attached neutral point of section (steelwork)
ANSTYP
word
Type of answer NONE, REAL, WORD, TEXT or BOOL
ANSW
real
Answer, when a real is expected
ANTY
string(120)
Analysis type
ANYCHA
logical
True if chamfer is defined on any edge
AOBJS
element(500)
Reference Array of all Model currently participating in ASSOCs
AOD
real
Arrive Ppoint outside diameter
AOFCEL
integer
Number of connected elements
APAR
real(100)
Attached catalogue parameters
APARMS
real(9)
All parameters
APDT
string(12)
Date of approval
APOF
real(2)
Leaderline attachment point
APOFTX
string(80)
Leaderline attachment point text
APOS
pos
Arrive position
APOSE
real
Easting of arrive position
APOSN
real
Northing of arrive position
APOSU
real
Upping of arrive position
APPL
string(20)
Application
APPR
string(1000)
Approver
APRO
real
Spot value of property A
APTDAT
real(5)
Annotation Point 2D Data
AQAANG
real
Angle between alignment direction of arrive pp and previous
AQANG
real
Angle between arrive Ppoint and previous component
AQBORE
logical
TRUE if arrive Ppoint has same bore as previous
AQCON
logical
TRUE if arrive Ppoint has Correct connection type
AQOFF
real
Offset between arrive Ppoint and previous component
ARCDAT
blob(2147483647)
Archive Binary Data
AREA
integer
Area
AREAEX
logical
True if area exists for DB
AREARE
element
Area reference
ARMMTL
element
Armour material
ARMRED
logical
Indicating whether CABD is armoured
ARNO
integer
Picture directory area number
ARRHEI
real
Arrive height
ARRI
integer
Arrive Ppoint
ARRWID
real
Arrive width
ASBPAN
element
Assembly base panel reference
ASBUIL
string(1000)
Assembly build strategy
ASCODE
string
Anno selection code
ASDEST
string(120)
Assembly destination
ASDIM
real(3)
Assembly dimension
ASECOG
real(3)
Assembly estimated centre of gravity
ASEWEI
real
Assembly estimated weight
ASFBR
logical
Spooling marker for arrive tube
ASIOWN
element(500)
Assembly item referring to element
ASIQUA
integer
Assembly item quantity
ASLSBSTANDARD
element
ASL Substandard Reference
ASLSTANDARD
element
ASL Standard Reference
ASMBLB
logical
True if element is possible to assemble
ASMBLD
logical
True if element is assembled
ASMBLR
element
Assembly reference
ASMBLS
string
A for assembled elements, NA for not assembled elements
ASMBLX
string(120)
Assembly reference as text
ASMBS
element(500)
Reference Array of all association members using element
ASMOWN
element(500)
Assembly referring to element
ASNAME
string(50)
Local assembly name
ASNORM
dir
Assembly normal
ASORI
integer
Predefined assembly orientation
ASORIS
string(20)
Predefined assembly orientation string
ASPART
logical
True if assembly part.
ASPLNO
integer
Number of assembly plate parts
ASPRNO
integer
Number of profiles on assembly part
ASPWLE
real
Total length of weld in assembly part
ASREF
element
Assembly reference
ASRF
element
ADP annotation symbol library ref
ASSCIA
element(500)
Reference Array of all associate elements used with constraints
ASSDFS
element(500)
Reference Array of all ASSDEFs
ASSEQ
integer
Assembly sequence
ASSNST
element
Assembly Nest
ASSOS
element(500)
Reference Array of all associations with constraints
ASSTAR
element
Association Target Reference
ASSTMPREFERENCE
element
Assembly Template Reference
ASTAB
word(15)
ADP association table
ASTEXT
string(500)
attr
Attribute value as text
ASTMBS
element(500)
Reference Array of all association members targeting element
ASUB
real
Angle subtended
ASVDIR
dir
Assembly view direction
ASWLOC
string(120)
Assembly working location
ATCONN
element(500)
List of elements connected to attachment
ATCORR
real
Arrive tube corrosion allowance
ATEX
string(1000)
Label Text
ATLE
real
Length of arrive implied tube
ATLS
word(50)
Access type list
ATNA
word
Attribute name
ATOL
integer
Arc tolerance
ATOP
pos
Top of arrive pipe
ATQUALIFIER
string(1000)
Attribute qualifier
ATSTLEN
real
Arrive Tube Stock Length
ATTC
word
Attached connection type
ATTDST
word(2000)
List the distributed attributes, default gives all udas
ATTLIST
word(2000)
List of all attributes for element
ATTMOD
logical
attr
True if specified attribute has been modified this session
ATTMODC
logical
attr
True if specified attribute has been modified since comparison date
ATTMODLIST
word(500)
integer
List of attributes modified since given session
ATTMODLISTC
word(500)
List of attributes modified since comparison date
ATTNAM
string(32)
Attribute Name expression for ATTRRL elements
ATTOUT
word(2000)
List of all attributes excluding hidden ones, i.e as output in "Q ATT"
ATTRAW
word(2000)
List of raw attributes
ATTRUL
string(1000)
Attribute Rule expression for ATTRRL elements
ATTSET
word
Set attribute with result
ATTSIZE
integer
attr
Actual size of attribute
ATTY
word
Attachment type
ATWALL
real
Arrive tube wall thickness
ATWLEN
real
Assembly total weld length
ATWREF
element
Arrive tube wall thickness reference
AUTCOL
real(3)
Design rgb autocolour
AUTCRE
logical
Set true to automatically create the element.
AUTH
string(1000)
Author
AUXPOS
real(2)
Auxiliary function definition point
AVBITY
string(25)
Availablity of material instance
AVRAD
real
Average radius for a CTOR or RTOR
AWALLT
real
Arrive wall thickness
AWDARR
logical
Auto weld arrive flange
AWDFLN
logical
Bending machine accepts autowelded flanges
AWDLEV
logical
Auto weld leave flange
AWDORF
element(1500)
Weld owners attribute on AWELD elements
AWDOWN
integer(3)
Table linking AWELD elements to piping components
AWDREF
element(20)
Return reference to AWELD element
AWELDS
integer(20)
Weld numbers of attached welds
AWQEX
logical
Allow Quality Exchange
AWTHEX
logical
Allow Thickness Exchange
AXIDIR
dir
Axis direction applied to repeat
AXIPOS
pos
Axis position applied to repeat
AXISID
string(20)
Axis ID
AXISLA
string(20)
Axis Label
AXSPRI
logical
Is principle Axes Symbol
AXSSIZ
real
AXESYM nominal size
AXSTYP
word
Axes Symbol type
AYDIR
dir
Arrive Y axis direction
AZDIR
dir
Arrive alignment direction
AZID
real
Default Azimuth value
AZIF
real
Azimuth attractor factor
AZIL
real(2)
Azimuth limits (Min/Max)
AZIS
logical
Azimuth set flag - ignore Azimuth values if FALSE
