Data Model
Property Database
Property Database Elements
: Cable Properties Element (CABDATA)
Attributes:
Name
Name of the element
Outdiameter
Outside diameter
Outsdiameter
Outside shield diameter
Uweight
Unit pipe weight
Resistance
Resistance
Reactance
Reactance
Impedance
Impedance
MinBend
Minimum Bend Radius
CondGroup
No of Conductor Groups
Dinterference
Default Interference class
VoltAC
Voltage AC
VoltDC
Voltage DC
Current
Current
GapAllowance
Gap Allowance
XArea
Cross sectional area
Nogrps
Number of groups
Grptyp
Text storing group type for cable
Oascr
Indicates screened or shielded
Grpscr
Indicates screened or shielded group
Armred
Indicating whether CABD is armoured
Ecorsz
Size of the earth core
Intemp
Insulation temperature
AmTemp
Ampacity Temperature
Noecor
Number of earth cores
Noncor
Number of neutral cores
Usecde
Text storing user code for cable
CataNo
Text storing unique display name for Cable
AlwUse
Indicates whether or not catalogue can be used in the project
MinVlt
Minimum voltage
MaxVlt
Maximum voltage
Description
Description of the element
Vltrng
Voltage Range
Corsz
Size of the core
Ncorsz
Size of the neutral core
Candrm
Can drum
Cutalw
Cutting allowance
Cutmin
Cutting allowance minimum length
Drumln
Drum length
Innshd
Inner sheath diameter
Manufr
Manufacturer
Outshd
Outer sheath diameter
Minrad
Minimum bend radius
Pultsn
Pulling tension
Remrks
Remarks
Cabcol
Cable colour
Oshmtl
Outer sheath material
Ishmtl
Inner sheath material
Armmtl
Armour material
Inslev
Insulation level
Conmtl
Conductor material
Cresis
Conductor resistance
Creact
Conductor reactance
Cimped
Conductor impedance
Eresis
Earth resistance
Ereact
Earth reactance
Eimped
Earth impedance
Masspl
Mass per unit Length
Corcod
Core code
Legal Owners:
Sorting Category Element (CMPTYPE)
Legal Members:
None
