Common Functionality
AVEVA NET Gateway for AVEVA IE&D : EIWM and RVM Files
The EIWM file and the RVM file(s) are associated to each other using the is identified by association. The exception is that the EIWM file does not include any associations between the elements by default. To view associations between elements in AVEVA NET™, specify the associations explicitly using the Associations part of the AVEVA NET Gateway Config window. Refer to Associations for further information.
