Common Functionality
AVEVA NET Gateway for AVEVA IE&D : Context Configuration
Use the Context Configuration part of the AVEVA NET Gateway Export window to specify a context name, file suffix and a dataset for the data export.
Enter a name for the context. To specify a nested context, enter the highest context followed by a + symbol. For example, SRP+PPD+VPD. By default, the field is populated with PROJECTCONTEXT.
Select the Generate folder.vnet check box to specify if a folder.vnet file is generated. The folder.vnet file contains information about the class in which the generated RMV file is placed and the context in which the object is saved. By default, the check box is selected.
Select the Generate trigger.start check box to specify if the output files (EIWM and RVM) are automatically picked for processing into AVEVA NET™ by the Import Controller. By default, the check box is deselected. If the check box is selected, make sure that the staging area of the output files is listed as a watched folder in the Import Controller.
