Common Functionality
AVEVA NET Gateway for AVEVA IE&D : Selection
Use the Selection part of the AVEVA NET Gateway Export window to specify the elements for export.
The Element List displays the selected elements for export.
The Type column displays the element type and the Name column displays the name of the element for export.
Use Add to add elements to the Element List. Use the adjacent drop-down list to specify the element selection.
Use Remove to remove the selected element from the element list.
Use Remove All to remove all elements from the element list.
The Configuration Selection displays the available export configurations for data export.
The Configuration column displays the available configurations. Select the Selected check box to specify the configuration to be used for export.
