Use the Export Options part of the
AVEVA NET Gateway Config window to specify export settings for the configuration.
Select the Evaluate All Positions WRT /* check box to specify if the elements must be evaluated from their root nodes in AVEVA E3Dâ„¢. By default, the check box is deselected.
Select the Include (0) Values check box to include elements that have the value 0 (zero) in the export. By default, the check box is deselected.
