Use the Associations part of the
AVEVA NET Gateway Config window to add, modify and delete associations between element types. Element associations are reflected in the EIWM file.
        The Element column displays element associations for the element types selected in the
Element Selection and Filters part of the
AVEVA NET Gateway Config window. Use the
Element drop-down list to select an element type.
        The Element List column displays available elements for association with the currently selected element type. Use the
Element List drop-down list to select an associated element type.
