Common Functionality
Integration with AVEVA ERM : Settings
The grid is populated with the added filters, use the Select for Publish check box to preview the information to be published in the Publish to AVEVA ERM window.
Use the functionality to configure the AVEVA Integration Service.
If selected, automatically loads data in the Notifications window, if the count is less than the number specified.
Use Save to save the information entered into the Settings window, this also saves the location of the material mapping file currently mentioned in the Material Category Mapping window. When the Material Category Mapping widow is next opened, the material mapping file is opened from the same location.
Use Reset to populate the Settings window with the last saved version.
