The Test Project Communications window will display a message giving the time taken to contact the remote location if successful, or informing you that there is a communication failure, in which case, one or both of the daemons must be re-started.
Ping Results will display communications messages once you click
Apply. You can click
Clear Results to remove all messages on the Ping Results list.
